jarrodblake's Avatar
Who makes the widest fiberglass long hood front fenders?
I'm getting ready to order fenders and would like something wider then 9 inches up front. Anyone know who makes a set of wide long hood fenders in fiberglass? The widest I have found for long hoods are 9 inches. I will be running 996 Front Suspension so I will need more room for wide wheels.
Old 10-18-2014, 09:39 AM
jamesjedi's Avatar
Check gt-racing. The fender flare is the same 9 inches for long and short hood. However, if you then used 934 flare(which are added to the turbo flares), it would be wider.
Also, you could use the extra wide short hood flare, and add the turn signal to it.
Old 10-20-2014, 08:03 AM
rkeele's Avatar
flairs
American international racing makes a 10" front fender for short hood RSR I believe they have the add on pieces you will need like light box& little fiberglass piece to turn the fenders into longhood.
Old 10-20-2014, 09:00 AM
What suspension are you using in the back?... multi-link? Do you have any pics of how it's going? -- Disregard.... just found your other thread.
thanks
Old 10-20-2014, 10:22 AM
