sugarwood's Avatar
Can someone review the compression test vs. leakdown vs. Italian tuneup debate?
I recall a debate a while back when someone got a bad compression reading and people said that does not mean anything definitive. Like it could just mean the valve might just have some deposits that may get burnt off after a spirited drive. Am I remembering correctly? Is this a possible outcome to a bad compression test?
Is a leakdown test more conclusive than a compression test? Or could the same fault/remedy potentially apply to a bad leakdown? I can't remember if one was more definitive than the other.
I am asking since another poster here has received a bad compression test on a cylinder. On his behalf, and for forum documentation, I am just wondering if that 100% means top end job.
Is Italian tune-up sometimes a remedy for bad compression test?
Is Italian tune-up sometimes a remedy for bad leakdown test?
What situation calls for an Italian tune up as a possible fix?
1986 Bosch Icon Wipers coupe.
Old 05-22-2020, 11:57 AM
Flat Six
Flat Six's Avatar
Compression test gives you cylinder pressure readings & tells you if you have leakage somewhere.
Leakdown test tells you if you have leakage somewhere & can help you identify what's not sealing properly (intake valve, exhaust valve, rings).
Italian tune-up can help blow out some carbon, so if there's a small bit on a valve seat that's keeping the valve from seating fully it might get heated up & blown out. IMO, Italian tune-up probably won't do much for worn rings but might help reduce some oil leakage by heat cycling gaskets, etc.
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 05-22-2020, 12:08 PM
scarceller's Avatar
In the 911 Engine a bad compression can also be valve lash to tight if done on a cold Engine. The valve lash grows wider by 3X when the motor is hot. A 0.1mm lash will grow to near 0.3mm fully warm motor. And the lash gets tighter as the Engine ages with milage, so it's possible to have a valve slightly hung open on a cold engine that has not had a proper valve adjustment.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 05-22-2020, 12:28 PM
famoroso's Avatar
Steve Wong tuned my 1988 on a chassis dyno a few years ago. We did 10 pulls. During one of the early pulls a fair amount of "stuff" exited the exhaust tip (car has a pre-muffler and Dansk sport exhaust), it wasn't anywhere near rolling coal, but it was noticeable. Both Steve and the dyno operator commented regarding "blowing out the carbon."
I don't know that you can duplicate the loads associated with dyno pulls, but it's worth a shot.
As an aside, first pull showed 190hp, last pull 210hp (car had 55k miles, the aforementioned exhaust, open airbox and Web 20/21 cams). May have been one of the happiest days of my life. 🤣
https://amoroso.smugmug.com/1988-Porsche-911-M491-M470-Poi/1988-911-Dyno-tune-at-Game
Frank Amoroso
911 M491 / M470 coupes:
1987 GP Wht / Blk "Apollo"
1987 Gemini Blue / Blk "Gemini"
1989 GP Wht / Blk "Vents"
Old 05-23-2020, 02:40 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Lots of wife’s tales on differential compression testing. Unless it’s done HOT it’s rolling the dice with accuracy.
Done a couple thousand of these:
https://www.lycoming.com/sites/default/files/Cylinder%20Compression.pdf
http://continental.aero/xPublications/xService%20Bulletins/ECi%20Archives/10-4/
Without the ability to rock the piston back and forth it’s almost impossible to get a perfect ring seal consistently. For a car, oil consumption and spark plug reading should be enough. The simple act of removing a spark plug can dislodge carbon into the cylinder and possibly under a valve. The best use of the test is as a diagnostic before there is a problem.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 05-23-2020, 07:16 AM
