#8 Main bearing O-ring
This is a crosspost from the turbo section.
The earlier 911/930 used an O-ring for the #8 main bearing that was 50mm x 4.0mm. The newer 911/930, I think about 1984-86 and later used a #8 bearing O-ring that is 51mm x 4.5mm. I read on another thread that the newer #8 main bearing 51mm x 4.5 can be used on the earlier engines. Was there a change in the #8 main bearing O-ring groove dimensions or does the newer 51mm x 4.5mm O-ring just happen to fit in the same size O-ring groove that the 50mm x 4.0mm fit in the #8 main bearing? Usually O-ring groves are specifically sized to fit a specific O-ring.
Any experience with this issue?
Rahl
1976 930 turbo Carrera, "Ubich". Mostly stock, lightly sweetened. She’s an angry schwierigkeit. She doesn’t want flowers, she just wants to dance! And when she does, she shakes her hips to the rythem of the road. Drive her like you hate her!
Old 05-27-2020, 06:50 PM
Walt Fricke's Avatar
The #8 bearing for my '82 SC motor is identical to the #8s from my 1977, and from a Grady Clay short stroke 2.5 (66x88mm). When I rebuilt the SC in 1989 or so, I used the larger, newer style, O ring. All these #8s are identical. Same with the 2.7 and 2.8 race motors, which had #8s from engines earlier than the SCs. No issue I can see to using the 51x4.5mm O ring in every air cooled 911. They all seem to accept the same #8, with the latest PN being a 964 part. However, my hands on experience stops with the SCs.
When I heard (can't find where)that Porsche had switched to the slightly larger O ring for the SCs, and its use was recommended on the older cars, I began using that on my older engines, with no issues. Anything to avoid a leak past this ring.
Old 05-28-2020, 12:11 AM
Thanks Walt! I was hoping that you would reply as I recall it was your thread that I first read about the updated O-ring being used for the #8 main bearing. My gasket kit from EBS appears to only have the 50 x 4.0 mm O-ring in the kit so it looks like I will need to order it separately from our host.
Thanks again,
Rahl
Old 05-28-2020, 08:32 AM
