-   -   Compression tester (http://forums.pelicanparts.com/porsche-911-technical-forum/1062622-compression-tester.html)
The_PS 05-29-2020 01:41 PM
Compression tester
How the $&@* do you thread a compression tester into a 3.2? I have a pretty standard actron tester. It just flops around and never threads in. Is there a better tool for this?
Flat6pac 05-29-2020 02:51 PM
I shorten the hose, gives more threading control
Bruce
nene 05-29-2020 03:24 PM
I went through the same PAIN when doing a leak-down test.
I left the hose piece in the sun to straighten it, as this one had a large curve/bend which made it more difficult. Eventually I was able to do all 6, but was a bit frustrating.
Serge
dannobee 05-29-2020 04:40 PM
The snap-on testers have the short section that screws into the spark plug hole. The gauge part has a quick connect that attaches to the short section. The other one piece testers that I've used have been a pain in the butt, comparatively.
The_PS 05-29-2020 05:43 PM
Smart. I’ll try that. Got a spare hose and barb fitting anyways.
rwest 05-29-2020 05:58 PM
This adapter works well.
https://www.stomskiracing.com/products/leak-down-compression-adapter
Solamar 05-29-2020 06:13 PM
About half way down this thread is my technique. Chaser tube-
http://forums.pelicanparts.com/porsche-911-technical-forum/1053367-chasing-leak-down-after-valve-job.html#post10805092
clarkd 05-30-2020 05:14 AM
http://forums.pelicanparts.com/uploa...1590840789.jpg
Frugal man special
