Dirt collecting in engine compartment
I spent a fair amount of time cleaning up my engine compartment and am constantly amazed at the amount of dirt (sand?) that accumulates in all the crevices. I have put on several thousand miles of back country roads over the past few months, but the amount of dirt looks like I've been rallying dirt roads (I have not).
How is the dirt getting in? The engine seal is good, I do not have a sound pad and the foam blocks in front of the shock tower are gone. Is the dirt coming in from in-front of the shock tower? The foam blocks don't look like they would do a very good job of blocking dirt... If it is from in-front of the shock tower, is there a better solution to seal that area? Photo when clean -
1978 SC Targa |
The giant fan right in front sucks in air and all the dirt that is in the air in massive volumes.
It is just going to happen if you drive it. Just like washing the rest of the car, it is just part of the result of driving a car. Nothing will stop it. Pretty engine compartment.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
And if you think about it, the tires are kicking up a cloud of dust, that the fan sucks in. That fan pumps a lot of air.
Get a Tesla perhaps...
RSA Pinky Helga Turtle Carrera Luigi CDtdi |
Ideally the fan is pulling air in from the top of the car; if pulling from below you recycle hot air in addition to dirt. Best to seal off the bottom from the top as best you can. In addition to keeping the engine bay clean it helps keep your cylinder and head fins clean.
Sent from my Nokia 7.1 using Tapatalk |
AutoBahned
My advice is to have a few whiskies before looking at the tops of your tail lights inside the fenders...
Where are all of fuses and the rest of the junk that should be on the left hand side, next to the fuel filter??
Still here
^^^Interesting. Probably a good idea to strap down that coil wire to the dizzy.
Over my dead body ![]() Better yet, check out the bracket on the inner front fender by the washer res. Hand fulls of muck stuck in there waiting to rot out your inner fender.
1978 SC Targa |
I deleted all that mess. Not running an assist fan or rear defroster so most of it was useless. I did save the jumper port to set idle.
1978 SC Targa |
I agree it doesn't look right...
1978 SC Targa |
someone said: "dirt don't slow you down."
it's an engine compartment at the rear of a car, the area where dirt gets whirled up.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
I went through this area recently and was shocked at how much crap was jammed up there. Had to be more than a pound or two total...
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc. '07 Boxter |
Not concourse correct, but I used high temperature PU foam to replace the blocks that crumbled out of my Targa. That sealed well.
IG @Drola964 1973 BMW 2002 1990 964 C2 2007 GT3 2014 Ram 2500 Cummins |
1986 Bosch Icon Wipers coupe. |
Solamar, what do you use to keep that fan blade polished.
Walt 82SC 3.0 81SC 3.6 |
Just personal preference, I prefer that engine compartment. It is functional, with AC and heat and the way it was designed. Maybe living in San Diego AC is just not needed, but having been there I do know it gets to high 80s and in the sun the inside of the car can get HOT.
That is why Porsche made lots of 911s. You can have yours the way you like it, and I can have mine my way. Mine engine compartment is clean enough for a road car. It has been to California three times. And to Maine, and Canada and 40 total states. It is nice enough that the dealer invited me to display my car at the introduction party of the new 2020 911. I do indeed appreciate Concours cars, I just never will have one, I drive mine way to much.
cycling has-been
someone also said 'ever see a dirty racecar before the green flag ?'
dirt does slow you down.
73 911T MFI, 76 912E, 77 Turbo Carrera |
Ayo Irpin, Ukraine!
"How's the dirt getting in?"
You know that big grill on the top of your engine lid???????? It's a bit of a secret but, it lets air into the engine compartment to cool the engine.
Harmlessly passing gas in the grassland away; Only dimly aware of a certain smell in the air |
