CIS operating pressure.
At what pressure does CIS work?
Until someone that knows something chimes in....
Fuel pump pressure around 100 psi Step down to system pressure in fuel distributor to 65-ish Injectors spray at system pressure Control pressure (20-40-ish psi range) regulates how much pressure the FD plunger fights back with against the air sensor. |
Depends on the application, CIS covers a lot of models.
So what would the highest pressure be? Bob has pressure at the fuel pump at 100PSI, anything operate higher? Looking to have fuel lines made and want to make sure the lines can handle the CIS pressure.
under pressure
I thought some of the Bosch CIS pumps would dead-head at ~8.5 bar but can't seem to find that reference.
Is Len (BoxsterGT) still making fuel lines? He's been a good resource in the past. |
pressure
I went back through my docs and found this, which show max pressure for.....what i have noted as the 979 pump. As you can see...at what appears to be no flow, the pressure is 11 bar. (154psi).
http://forums.pelicanparts.com/uploa...1590952585.gif |
You are purchasing a brand new Genuine Bosch inline fuel pump. Bosch 0 580 254 979 Inline Fuel Pump Bosch 979 fuel pumps mount inline (out side of your gas tank), most commonly rear center under your car or truck. Each Bosch 0-580-254-979 fuel pump provides 165LPH of flow and operate at 72.5 PSI. Bosch 979 Fuel Pump Specs: Bosch Part Number: 0580254979 Minimum Current: 12 Volts Operating Pressure: 72.5 PSI (5 Bar) Minimum Flow @ Outlet: 43.5 GPH (165 LPH) Fuel Pump Location: In-Line Fuel Pump Connections: Inlet: M14 x 1.5 Outlet: M12 x 1.5 Electrical: Positive M5 / Negative M4 |
I would go 300 psi minimum for new lines. Steel should be way more than that. |
| All times are GMT -8. The time now is 06:21 PM. |
