-   -   Cowl to fender seal - 2 width choices - why? (http://forums.pelicanparts.com/porsche-911-technical-forum/1062884-cowl-fender-seal-2-width-choices-why.html)
911finally 06-01-2020 11:03 AM
hi all, did some searching and found this thread http://forums.pelicanparts.com/porsche-911-technical-forum/1018037-front-fender-cowl-seals.html
Didn't see a specific answer to my question though... our host sells both 6.5MM and 4.3MM versions of fender to cowl seals. Is there a reason? My car is a 85 ROW coupe (which is FINALLY almost done being freshly painted, story for another day) and I'd like to replace as much old trim as possible.
does it matter which one I use? I assume the difference is in depth (invisible below panels) as opposed to width (visible between panels)??
Thanks!
911finally 06-01-2020 04:36 PM
Ok so the measure is width across the panels not depth. Been advised to buy wider version.
73pcar 06-02-2020 06:49 AM
You can use either one, but you'll find that one will fit better than the other depending on the fender to cowl gap you have. I use the wider versions in my early 911s...even though the thinner version is 'correct'....I just prefer how it covers the gap.
