LinkBack | Thread Tools | Rate Thread |
bleeding the breaks, what is with that little hose that spit the fluid out all over
Thank you everyone who helped with the disk job. I love this site.
I used the little pressure tank to bleed my breaks. I cleaned it out filled it up with pretty blue racing fluid and started pumping. It got up to about 5 lbs and I kept pumping since 5lbs didn't seem like enough. Then I heard the dripping...AAAAAAAAAAAAHHH!!! I must have had a cup of pretty blue fluid on the floor, dripping all over the underside of my car AAAAAAAAAHHHHHHHHHHH!!! My poor daughter was standing there just chatting away at a million miles a minute. I kept as calm as I could. "When are you gonna be done Dad, When are you gonna be done Dad, When are you gonna be done Dad, When are you gonna be done Dad" AAAAAAAAAAHHHHHHHHHHHHHHHH!!!! Well... I found a funny little hose with a bolt clamped in it that fit right over the hose that was leaking. I was wondering why it was in that little pump tank when I cleaned it. So I guess my question is, if someone would be so kind to answer, How much pressure do you need to put in the tank after the little hose is blocked off? What exactly is the that little pisser hose there for? Does anyone have a not so messy procedure for bleeding this way? I still have new rear rotors to do. But that will be after I enjoy my new front ones for a little while Thats me in the break fluid
1979 911 SC Targa http://www.pelicanparts.com/gallery/Mike_Kast Last edited by Mike Kast; 04-13-2003 at 04:52 PM.. |
That little hose is the over flow for the brake fluid resevior. Before you pump any pressure to the system make sure you clamp the hose at the resevoir. I too found out the hard way.
Tom
Ice Green '77 Targa 3.6 w/ Steve Wong chip One Way To Get More Horsepower Is To Get A Bigger Horse! "I couldn't find the sports car of my dreams, so I built it myself" Ferdinand Porsche |
Automotive Monomaniac
I too found out the hard way about needing to clamp that hose. What a mess!
You don't need a ton of pressure on the bleeder. Start with 5 psi, then if there isn't enough flow, increase it.
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
Mike,
I don't think there is a back yard mechanic on this board who hasn't found that out the hard way. It's a little late, but I am afraid you might have wasted that pretty blue fluid. In my car, you have to disconnect the rear brake lines to take off the caliper. The brakes are attached with 2 screws and just slide on the rear hub. Actually this board sucks... the wallet dry. The people and search function on this board make just about any job possible if you have the time and the patience.
Neil '73 911S targa |
one of gods prototypes
wow.........i wasn't going to say anything because i figured it out but.........
i just found out what the little hose is for about 20 minutes ago spent the last 20 minutes cleaning up the mess small world.........
Brought to you by Carl's Jr. |
There are instructions on the bleeder. One of the steps listed is to hook up the bleeder without brake fluid in it and do a pressure test to see if there is a leak. If people would do this, they would find the overflow line before they dump a bunch of brake fluid down it.
Jim
Unregistered
That brake fluid will eat paint if left on for very long, make sure you get it all cleaned up as quickly as possible.
You do not have permissi
Time to make sure the overflow hose which runs through the left fender and inside the trunk hasen't cracked. Since brake fluid is hydroscopic, you might be able to clean it up with water if it hasen't gone through the paint.
My bleeder came with the car. I got an overview from Leland, the previous owner, about how it works. The overview unfortunately didn't include the overflow tube. I cleaned it up as fast as I could with water. Why the overflow? Is it in case your brakes are so overheated the fluid is boiling over? Does it expand?
Anyway... My brakes are incredible now. My car is 40 miles away from 230,000 miles and stopping on the dime!
1979 911 SC Targa http://www.pelicanparts.com/gallery/Mike_Kast |
yea i was in there with a roll of paper towels and parts cleaner.........
and a manual to the bleeder? what's that?
I'm assuming we're talking about a Motive Products power bleeder. On Decal, on side of bleeder, step 4: Tighten pump cap onto empty Power Bleeder and pressurize to 10 psi. Check for leaks at fluid reservoir and at Power Bleeder hose connections.........
Jim
Mike - just a thank you in advance. I reinstall my calipers next weekend and will be pressure bleeding. I would also be cleaning up brake fluid were it not for this post.
Chris M 1985 911 Carrera w/ 3.6 |
ohhhhhhh... right on the bottle...You'd a thunk I'd a looked at the thing wouldn't ya!
Look Jim, your an engineer. Have a little sympathy for the brain dead among us. Or the fact that I have to live this way!
that was a joke Jim...
I've also spilled blue fluid on the floor through a set of rotten reservoir line rubber bushings on the the top of the master cylinder. The system held pressure for a while and then started leaking when I began bleeding! I just got a little further into the process before I made my mess! I had to stop and finish the next weekend when a new set of bushings came in from Pelican. Learned how to take the master cylinder out too. Cheers, Jim
uhggg... thats even worse, that brake fluid is some amazing paint remover.
Senior Member
Seems Lee gave it all away. What caused him to lose his mind?
'81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M. |
I think Jim is trying to make up from Warren's absence
![]() I have done the Power Bleeder overflow trick. It's easy to forget.
Mark Szabo 1986 911 Targa 3.2 (I will miss you) 1985 Scirocco 8V (I will not miss you) 1986 Dodge B150 Ram Van (I can't believe I got $200 for you) 1987 Escort 5-speed 1.9 RIP |
He did give it all away though. I got all the factory manuals and 6 books besides 3 oil filters a new belt, some tools, new cap and wires, a bag of fuses... all sorts of stuff I haven't even sorted out yet. I think I got a real good deal but there is a few things I'm discovering that are quite mysterious. I'm sort of on the fence about bugging him too much though. He sold the car and it's out of his hands now. It didn't come with a warrenty
I realized that this board is almost a better version of Carfax...
you could search for all of Lelands posts...which are ALOT, and get a good blow by blow history of his car... |
