Leaky Injector Connector
http://forums.pelicanparts.com/uploa...1591485785.jpg
Look at the difference between one (very wet) and two(bone dry). I have taken the fitting apart twice and cleaned and reseated, still seeping. Is there supposed to be an O ring or seal in there? Thanks |
Swap injectors. Maybe you need a new injector.
Fuel line........
From the picture you had posted, the fuel line to the injector is not properly oriented. You could see that it is going to the fitting at an angle. Loosen the fitting and re-align the metal fuel line. This is a compression fitting and relies on good surface to surface contact. Keep us posted.
Tony |
Are you sure the leaking is coming from the fitting?
There's an O-ring on the injector which seals it against the housing.
https://www.pelicanparts.com/techarticles/Porsche_911/05-FUEL-Injector_O-Ring_and_Sleeve_Replacement/05-FUEL-Injector_O-Ring_and_Sleeve_Replacement.htm |
If the fuel really would come up from the injectors outlet upwards through the manifold and the injectors seal .... then then valve would be permanently closed to make this kind of closed chamber that overflowing till the fuel gets squeezed out of the injectors sealing ring |
Thanks guys |
| All times are GMT -8. The time now is 01:47 PM. |
