Leaky Injector Connector
![]() Look at the difference between one (very wet) and two(bone dry). I have taken the fitting apart twice and cleaned and reseated, still seeping. Is there supposed to be an O ring or seal in there? Thanks |
Swap injectors. Maybe you need a new injector.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Fuel line........
From the picture you had posted, the fuel line to the injector is not properly oriented. You could see that it is going to the fitting at an angle. Loosen the fitting and re-align the metal fuel line. This is a compression fitting and relies on good surface to surface contact. Keep us posted.
Tony |
Are you sure the leaking is coming from the fitting?
Kevin Catellus Engineering catelluseng@gmail.com http://www.catellusengineering.com https://www.facebook.com/catelluseng/ |
Still here
There's an O-ring on the injector which seals it against the housing.
https://www.pelicanparts.com/techarticles/Porsche_911/05-FUEL-Injector_O-Ring_and_Sleeve_Replacement/05-FUEL-Injector_O-Ring_and_Sleeve_Replacement.htm |
I also guess it simply comes from the Fuel line thread which connects to the injector.
If the fuel really would come up from the injectors outlet upwards through the manifold and the injectors seal .... then then valve would be permanently closed to make this kind of closed chamber that overflowing till the fuel gets squeezed out of the injectors sealing ring
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models: https://nineelevenheaven.wordpress.com/english/ Last edited by AndrewCologne; 06-08-2020 at 08:41 AM.. |
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
