1975 911 fuel prime loss
If I let the car set for a couple of weeks the car loses it's prime and wont start. I replaced tank the pump and the fuel Accumulator, what else could it be thanks.
Old 06-06-2020, 03:06 PM
I do not think your problem is losing prime as the pump is lower than the fuel level, and I have never heard of a prime problem. I would put a CIS gauge set on your system and troubleshoot from there. Rob
Old 06-06-2020, 06:17 PM
Fuel pump running.........
The ‘75 has the FP running with the ignition switch @ ON position. Allow the FP to run several seconds before turning the ignition switch to START.
Tony
Old 06-07-2020, 06:40 AM
Even without a prime it should start with the cold start valve. Joe
Old 06-07-2020, 02:08 PM
There is a check valve on the fuel pump in the banjo fitting
Inexpensive, change it to hold pressure to the CIS.
Bruce
Old 06-07-2020, 02:48 PM
I believe he replaced the FP which comes with a brand new check valve if I'm not mistaken.
Old 06-07-2020, 05:08 PM
