<insert witty title here>
Christien's Avatar
Just got back from a test drive, VR looks fine - steady at 14v on the highway, down to 13.7 with headlights, 13.5 with headlights and AC. No spikes at all, on the highway or city streets. No smell at all. Couldn't get the tire to lock up on downshifts, either going straight or in a curve. Haven't had a chance to jack it up and get under it yet.
Old 06-09-2020, 09:40 AM
porsher
aston@ultrasw.c's Avatar
Porsches never act up on the test drive!
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 06-09-2020, 11:33 AM
Still here
pmax's Avatar
Any roadkill marks on the tire ?
Old 06-09-2020, 11:47 AM
Christien's Avatar
TBH, I'm wondering if it wasn't something like that that just got stuck somewhere, burned up, and is now gone.
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 06-09-2020, 11:57 AM
Originally Posted by RSTarga View Post
If double clutching eliminates the problem, could be sticking clutch.
Yes. If minimized when double-clutching, the clutch disk, if oil-fouled, will tend to grab instead of typically slip when torque continues from engine to gearbox.
If so, check rear main and/or input shaft seals.
Sherwood
Old 06-09-2020, 06:06 PM
DanielDudley's Avatar
Originally Posted by anglophone1 View Post
Clutch release bearing - mine made same noise- thought it was the belt.
A good thought. If it is the throw out bearing, it will become more obvious as time goes by.
Old 06-10-2020, 02:05 AM
Christien's Avatar
Ok, I'll keep an eye (and ear) on that.
Old 06-10-2020, 10:13 AM
It's a 914 ...
stownsen914's Avatar
See if you can (re) create the sound other ways to isolate the cause. Or just wait to see if it appears in other scenarios, or changes with time.
For example, if it is the throwout bearing, it ought to make the sound any time you depress the clutch and not just on downshifting. Try downshifting earlier or later than usual to see if the sound changes, or perhaps it may reveal that the timing of the sound with downshifting was coincidental, etc.
Old 06-10-2020, 02:29 PM
