Harpo's Avatar
WEVO shifter thread size
Good afternoon everyone,
Does anyone know the thread size & pitch for the top of the shifter where the shift knob threads on to? My guess is M14-1.5
Old 09-27-2020, 02:15 PM
speednme1's Avatar
should be an m6x1.00
Rey....77 930 "the Mistress"
Old 09-27-2020, 02:59 PM
Harpo's Avatar
Definitely way bigger than M6. The major thread diameter is 13.76mm
Old 09-27-2020, 03:30 PM
Harpo's Avatar
I want to install this but it has no internal threads. I'm hoping to install a Heli coil or time cert.
Old 09-27-2020, 03:33 PM
speednme1's Avatar
You’re correct that is M14
Old 09-27-2020, 05:25 PM
speednme1's Avatar
Is there a thread inside that thread? As in the wevo pic (11)...can you open that knob or is it sealed ?
https://www.wevo.com/Products/ShifterProducts/ShifterImages/WEVO_915_Shifter_INSTRUCTIONS_2009.pdf
Old 09-27-2020, 05:32 PM
Flojo's Avatar
The WEVO "modern" shift lever has a M6 thread inside.
When I got my Mahagoni custom made prototype 917-shiftknop I JB-welded a M6-hex-head screw inside.
works perfekt!
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 09-28-2020, 06:32 AM
Harpo's Avatar
update
Got my shift knob back from the machine shop with the M14-1.5 Heli coil installed inside. The ID of the shift knob was very close to the recommended drill size so no drilling was necessary just tapping with the specified tap and installation of the heli coil.
Old 10-15-2020, 10:30 AM
