Yay. It's a happy ending. Brake pedal is firm. Clutch works. And no more sticky rear calipers.
It's enough to make you tired of winning. |
Caveman Hammer Mechanic
Change the fluid every other year. Brake fluid absorbs water from the air and that lowers the boiling point. More importantly the water will drop out of suspension and proceed to the calipers and once there will start corroding the interior surfaces.
I use these: Introduction - Speed Bleeders - Russell Performance Products I can bleed all 4 calipers by myself in little more time than it takes to access the calipers.
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
| Tags |
| bleeding brakes , brakes calipers |
