Spedo needle sits until 30 MPH
My mechanical speedometer needle sits at zero until I get to about 30 MPH. After I reach that speed, needle moves as it should and reflects accurate MPH in all ranges above 30 MPH. If I stop and start up again, same issue- needle sits at zero until I reach 30 MPH -Whats the cause and the fix?
Old 11-16-2020, 04:08 PM
arbita1's Avatar
I had the same thing. Send it to Palo Alto Speedometers to be repaired.
Matt.
83 911SC
85.5 944 NA - Sold
Old 11-16-2020, 04:59 PM
PCA7GGR's Avatar
Try this before sending it to repair - pull out the speedo from dash, disconnect the cable then spray WD40 (or similar lubricant) into cable end.
Nothing ventured, nothing gained.
Sergio
The GT Lid Whisperer
PCA 42yrs - National DE Instructor / Ex-RGruppe #197
'19 718 Cayman S (9th Porsche/1st with PDK)
'14 Subaru Forester XT (Porsche support vehicle)
Old 11-16-2020, 05:28 PM
arbita1's Avatar
Good point although may not be cable driven.
@speedster911-What year is the car?
Matt.
83 911SC
85.5 944 NA - Sold
Old 11-17-2020, 01:33 AM
74 - mechanical spedo
Old 11-17-2020, 06:27 AM
dar636
Clean the grounding point associated with the instruments, I don't have a drawing at hand, sorry - I think mine was under the frunk near the brake master cylinder.
Old 11-17-2020, 09:34 AM
Walt Fricke's Avatar
Mechanical speedometers don't depend on electrical grounds (other than for instrument lighting), do they? The cable rotates a magnetic piece in the speedometer, which uses magnetic drag to turn a cup which surrounds the magnetic piece and is attached to the needle. A spiral spring is also attached to this cup/needle part, and it is designed and adjusted so that needle movement relates to speed of rotation.
Hence the importance of lubricant in the rather long cable assembly. And, if that isn't the problem, the best option is sending off to a speedometer repair shop - dealing with this yourself is sort of like trying to fix a wind up watch or clock.
Old 11-17-2020, 11:45 AM
