cmpski's Avatar
SWB steering issue
I'll start by saying I had the front suspension off to move the gas tank to run hard fuel lines through the tunnel. I've had the front suspension off 3 or 4 times without this issue.
When I button up the front suspension and steering box the splined shaft that connects to the steering box is off so far I can barley get the bearing on as the shaft is actually pressed up against metal by the upper mounting bracket hole. If I tighten the bearing in place it puts a strong side load on it and it clicks at about dead center and also causes the shaft to pinch to one side when the steering wheel is off. I've never run into this before. When I loosen the two bolts that hold the rack to the crossbar it goes into place. I tried loosening all front suspension contacts in case there was a bind somewhere and carefully retorqued the bolts. It didn't help. When the steering wheel is not connected to the steering box both the steering wheel and the steering box move all the way in both directions smooth as silk.
What gives? Do I need to rebuild the box, tie rods twisted, or?
The shaft should be pointing up not down.
Chris
1959 Auratium Green 356A Super w/ Rudge wheels
1970 Irish Green 914-6 w/2.2S
Current -1967 Bahama Yellow 912 POLO 2cam4 #1
Handles like a 912 and goes like a 911
www.reSeeWorks.com
Old 06-15-2020, 02:05 PM
Uncertifiable!!!
Uwon's Avatar
Odd. Do you have those large spacers (pucks) that lowers the steering rack to reduce bump steer? If so, one may not have been re-installed.
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 06-16-2020, 04:57 AM
cmpski's Avatar
No pucks. I'm going to release the tie rods and see if there slightly twisted.
www.reSeeWorks.com
Old 06-16-2020, 05:54 AM
cmpski's Avatar
I released the tie rod ends to see if they were off. It didn’t help. When the steering rack is just a little loose and pressure is on the rod to move it in the proper position you can see the whole rack wants to rotate. There are no pucks or washers between the rack and cross bar.
I put a long bolt in the rack and wiggled it to see if there was play and couldn't feel any.
I went home and blew this picture up and noticed a 180 degree scratch. What do you think? About the only thing left that I can think of is pull the rack and look inside. I would appreciate some feedback here.
www.reSeeWorks.com
Old 06-16-2020, 10:01 AM
cmpski's Avatar
I'm replacing the crossbar.
www.reSeeWorks.com
Old 06-17-2020, 03:15 PM
