Designer King
Paulporsche's Avatar
Resistor Plugs in Non Resistor Application?
I'm about to put a Pertronix Ignitor 2 in my 74-77 (formerly points) distributor to run my 10.3 CR 3.2L SC engine. I also have an MSD/Blaster2 CDI. I set the plug gap @.040"
I have used in the past both NGK BP6ES and Bosch W7DC plugs. Looks like there are no more plugs being produced in this range by these 2 manufacturers.
Can I switch to the resistor type plugs and still be OK? Will there be any problems or loss of performance with resistor plugs?
Thanks.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 06-16-2020, 06:57 PM
Designer King
As of this writing, NGK and Clewett have confirmed that there should be no negative effects from using resistor plugs.
Paul
Old 06-17-2020, 12:26 PM
Designer King
I have not been able to get through to MSD tech support, but everything I have been reading online indicaates that resistor plugs should not be a problem with their units.
Looking forward to my MSD/Pertronix/Clewett?BP6ERS combination.
Paul
Old 06-18-2020, 12:52 PM
Designer King
Looking forward to my MSD/Pertronix/Clewett/BP6ERS combination.
Paul
Old 06-18-2020, 12:54 PM
I ran into the same problem with finding NGK BP6ES. Dont be fooled by the NGK BP6ES on Amazon and Ebay. They are counterfeit. I purchased the NGK BPR6ES from a reputable mechanic shop. Was told NGK does not make BP6ES. Works fine with my MSD 6A and Petronix with Blaster coil.
Old 06-18-2020, 06:54 PM
proporsche's Avatar
Paul you cannot get hand on W4cc plugs?
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 06-18-2020, 11:29 PM
Designer King
Thanks Slant. Glad to hear that.
Ivan, I don't know. I've always used BP6 or W7 Bosch so I've never looked for W4CC.
Paul
Old 06-23-2020, 08:40 AM
