Brian Minson's Avatar
How the HELL do you remove the tie rods?
I am I just worn out from working in 110-degree heat in my garage today in Phoenix, Arizona, or am I doing something wrong?!?
Just removed everything but can't get the outer tierod to unscrew from the "rod" Shot PB in it several times, walked away, drank a little drink, and still won't budge!
Suggestions or nuggets of wisdom? I swear the ball joints are the originals from 1967!!! Augghhhh
Brian
https://youtu.be/MmEkqvWf_Yk
Old 06-03-2020, 07:11 PM
Heat. More than 110°. Torch.
206 637 4071
Old 06-03-2020, 09:57 PM
Once a friend of Cliff
juanbenae's Avatar
your wife is gunna be pissed you got greasy prints all over her pantry stepstool...
Old 06-03-2020, 10:14 PM
76 911S Targa
I used a pickle fork (ball joint tool) to span the inboard end and vise grips on the handle to turn each tie rod out.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 06-03-2020, 10:22 PM
Get a map gas torch and heat that end until it's glowing, repeat this several times then it should turn free. Some people heat then quench with penetrant or even water in a spray bottle but I find just the heat alone works.
Old 06-04-2020, 05:50 AM
Platinum Member
dad911's Avatar
Run it through the diswasher.
Old 06-04-2020, 10:37 AM
if they are the non turbo ones as they appear to be i just bend them down 90 degrees and use the rod end as a wrench to break them loose.
1976 914
1986 951
Old 06-04-2020, 11:07 AM
Two things you can try. Put the box end of a decent sized wrench over the ball stud and use the wrench for leverage. You can also use a pipe wrench to grip the outer tie rod. The harder you pull on a pipe wrench, the harder it bites.
Old 06-05-2020, 04:38 PM
you need to unlock the inner lock nuts at the rack end
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 06-05-2020, 05:07 PM
oops , you mean just the outer tie rod , are you turning the left threaded one left and right one right
check your thread direction
Old 06-05-2020, 05:10 PM
Update:
Picked up a MAP gas set up and heated the threads up, took a few tries but it finally came loose. I don't think these have been off the car since new!!!!
Thanks for the help guys, I recorded a video of pulling my front suspention apart for anyone in the future who wants to watch it.
Brian
Old 06-05-2020, 05:42 PM
petr916's Avatar
This work I am planning in close future. I am interested.
Petr ~
80' Euro Copper Brown Metalic 911 SC Targa - New for me
89' Alfa Romeo GTV V6 2.0 TB
Old 06-08-2020, 07:51 AM
Originally Posted by Brian Minson View Post
Update:
Brian
Brian this would be really helpful. I am about to do a front suspension overhaul. My email is sdgg91@gmail.com
Old 06-08-2020, 10:59 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
What Colingreen said. Use the tie rod as wrench. Get it to bend naturally at the inner pivot, close to 90 degrees and force it to turn counter clockwise. It will not break free. It will feel like your breaking somthing. The fun continues until you have turned it several revolutions. Did mine a couple weeks ago. Got to muscle up big boy.
Chris
Old 06-08-2020, 11:50 AM
I finally got everything torn apart and rebuilt, not hard at all... mostly just time-consuming the first time you do it. I recorded the entire process and over the next few days will edit and post the videos for those who want to see whats involved in rebuilding the front suspension in an early Porsche 911 or 912.
Here is the first video:
https://youtu.be/w-wIy0JkzRQ
Old 06-19-2020, 12:59 PM
