Big Red Rebuild Kit Question
I have a set of big reds i''ll be putting on my 964 along with uprights etc
I would like to do a rebuild on them like i've done many times before on so many different calipers. when i look for seal kits from our host I only get one per piston. the kit comes with a new piston, one seal and one dust shield. is there a kit that just has the seals and dust shields like every other caliper rebuild kit i've ever bought? my pistons are fine and there is no point in replacing them
IG @Drola964 1973 BMW 2002 1990 964 C2 2007 GT3 2014 Ram 2500 Cummins |
Hey Pedro and Bill,
Sorry to glom on but in the same vein, where can I get a rebuild kit for turbo-calipers on my '84 M491? I've looked several places or are they the same size and pistons as the Carrera items?
Scott "Houston, Tranquility Base here, the Eagle has landed" Silver 1984 M491 Sunroof Coupe |
i found this under 930 parts https://www.pelicanparts.com/catalog/SuperCat/0817/POR_0817_BRKCAL_pg2.htm hope that helps
Thank you
Well that's embarrassing, thanks Pedro
You can get seals only at https://racingbrake.com/ too
