Need help finding alarm wiring harnass
Hi all,
I need help locating my Alarm wiring harnass/connector. Looking at the wiring diagrams it should be right behind the gauges somewhere but I cannot seem to locate it ?
I want to use it to install a gps tracker/immobiliser and all the necessary connections should be right there on that 'plug'.
My car is a 85 Carrera (US) without alarm - can it be that the wiring for the alarm unit was not installed if the option wasn't factory installed ?
(I was looking for a plug like in this post : "No Cut" method for bypassing factory alarm )
1985 Carrera 3.2
Old 06-20-2020, 01:05 AM
What exactly are you looking for , I may have
Old 06-20-2020, 06:17 AM
It's behind the fresh air blower assembly on the passenger side. You have to remove the blower cover, hoses, the blower motor, and the attached ducts. There are two bolts on the motor, and one on a plastic duct directly in front of the blower. There are six screws holding in the intake screens where the hood meets the body and behind those, two screws that have to come out to remove the blower assembly.
Remove the hose at the bottom of the assembly, and then push the blower down to release it from the intake, and pull it out. You will see the alarm connectors.
Old 06-20-2020, 06:36 AM
Right, it a project in itself to get there then. I guess it's worth it instead of running new cables and splicing them in.
1985 Carrera 3.2
Old 06-20-2020, 08:48 AM
It's not as hard as it's been made out to be. Leave the bowden cables in place and work the assembly out. It's easier if you separate the motor from the housing, but not necessary.
Old 06-20-2020, 09:00 AM
Bill
1987 Marine Blue 911 Carrera Coupe RIP 01/2011
1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint
Old 06-20-2020, 09:54 AM
