87 3.2 Head temp sensor
What is the best way to remove and install the cyl head temp sensor?
Should be plenty of posts here if you search. Helps if you remove the driver's side rear wheel. Hardest part for me was installing the new rubber grommet on the engine tin. A little dish soap made it easy.
http://forums.pelicanparts.com/porsche-911-technical-forum/6578-head-temperature-sensor-replacement.html https://www.pelicanparts.com/techarticles/911_cyl_head_temp_sensor/911_cyl_head_temp_sensor.htm |
| All times are GMT -8. The time now is 01:05 AM. |
