87 3.2 Head temp sensor
What is the best way to remove and install the cyl head temp sensor?
Old 06-23-2020, 06:23 AM
Pedro '84 Coupe's Avatar
Should be plenty of posts here if you search. Helps if you remove the driver's side rear wheel. Hardest part for me was installing the new rubber grommet on the engine tin. A little dish soap made it easy.
Head Temperature Sensor Replacement
https://www.pelicanparts.com/techarticles/911_cyl_head_temp_sensor/911_cyl_head_temp_sensor.htm
2000 Boxster S and 2016 Audi A6
Old 06-23-2020, 06:59 AM
