77 Restorer
ARGH...transmission positioning spring missing
Reposting since I put it in the wrong forum...
Hi All:
I'm restoring a 1977 Targa 911 - and thank everyone on the forums so far for their invaluable help! I had the Wevo shifter put in, which works wonderfully from the old oatmeal search and find gearing previously. The car shifts ok, but occasionally grinds when going into second. So today I went under to look at the tolerances, ready to potentially adjust the stop screw to the 1.2 and 1mm distances. Angst ensued (and disappointment that my mechanic didn't find this) - there was no positioning spring attached to the positioning arm. And of course, the bolt was therefore flush with the positioning arm. An order to our hosts is in route, but anything I should now be evaluating given this finding?
TIA.
Bert
77 911 Targa (Maize, or Talbot yellow as the case may be)
04 C4S Cabriolet (sold)
Old 06-28-2020, 03:29 PM
Hello there!
I'm Rudy with Pelican Parts, let me know if this is the missing spring:
https://www.pelicanparts.com/More_Info/91530323200OEM.htm?pn=915-303-232-00-OEM&bt=Y&fs=0&SVSVSI=788
Old 06-28-2020, 04:18 PM
Hello there,
Thank you for being part of this community, I would like to share a relevant link that might inform you better about the Wevo shifter installation and any nuances about it:
https://bit.ly/wevoshifterinstallation
Old 06-28-2020, 06:23 PM
77 Restorer
Originally Posted by Rudy at Pelican Parts View Post
Hello there!
Hi Rudy:
Thanks - it's the transmission positioning spring - and it's back ordered. Much appreciate the response.
Best,
Bert
Bert
Old 06-29-2020, 08:09 PM
77 Restorer
Originally Posted by Nicolas at Pelican Parts View Post
Hello there,
Thanks very much! All installed and in use. Much appreciated the response.
Bert
Bert
Old 06-29-2020, 08:11 PM
ADDvanced's Avatar
When was the last time your gearbox was rebuilt?
IG@ADDvanced
Youtube@ADDvanced
www.gruvdesign.com
Old 06-30-2020, 12:00 AM
77 Restorer
About 13 years ago, from my understanding. That was before I had the car.
Bert
Old 06-30-2020, 02:37 PM
Tags
clutch adjustment , positioning spring , transmission
