billh1963's Avatar
Sump plate doesn't have a plug...only option is to pull the plate?
First time changing oil on my '76 2.7. Drained oil from tank and went to pull plug from sump plate and there's no plug! Since there is no side plug on the 2.7 I guess my only option is to drop the plate?
I don't want to do this for every oil change. Any nice after market plates other than the factory replacement?
Old 06-28-2020, 02:02 PM
Mine's the same and I'd love to see a plug on it. The reason it's lacking one is that the sump pump pickup fills the entire space behind it. I guess large pumps come with some disadvantages. It does make a nice warm oil fountain when you take it off!
___oOo___
1972 S 911 Targa kit
http://forums.pelicanparts.com/porsche-911-technical-forum/863768-thats-my-first-911-restoration-thread-72-911-s-back-grave-maybe.html
Old 06-28-2020, 02:08 PM
Our host has an aluminum replacement sump cover plate with a drain plug.
Porsche Oil Sump Plate Kit With Drain Plug
Old 06-28-2020, 02:25 PM
billh1963's Avatar
Wouldn't this one work, as well? I really don't want to replace the studs to use the aftermarket kit. That seems risky to me..
https://www.pelicanparts.com/catalog/SuperCat/0784/POR_0784_ENGOIL_pg3.htm#item11
Old 06-28-2020, 03:10 PM
I'm not sure if that cover will work.
There were modifications made to the pump that year increasing the output of the pressure side and the scavenger pump was slightly reduced. They also changed the oil flow by having the pressure relief going to the pressure pump suction vs the crankcase.
Someone with more knowledge will need to advise you on this cover.
Old 06-28-2020, 05:06 PM
Bill, I have several extras, pm address, I’ll send it down
Bruce
Old 06-28-2020, 05:41 PM
Just loosen it so it drools and have a beer while you wait.
206 637 4071
Old 06-28-2020, 06:00 PM
My 2.7 had a retrofit sump playe with a drain plug.
The drool& beer (or is it beer then drool lol) idea sounds like a good plan b
Old 06-28-2020, 07:35 PM
Bruce
Would you have any interest In selling one or two?
No hard feelings if not.
Tony
Old 06-28-2020, 09:30 PM
frankc's Avatar
The 2.7 sump plate had a drain plug. It appears that someone replaced your sump plate with a later style.
'73 911T RoW (Project)
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 06-28-2020, 10:10 PM
Bill Douglas's Avatar
I don't bother draining what sits in the sump plate. It's only about half a cup, or a full cup. Not when there are another two or three liters sitting in the oil lines and cooler.
Old 06-29-2020, 12:14 AM
This is a Porsche item I have fitted to mine with a drain plug. 930 101 902 00
Old 06-29-2020, 12:39 AM
sean m's Avatar
I have a 77 that had the same issue. I put in the one Harold above notes......no problem and easy to change the oil going forward.
Sean M
'77 911S Targa Ice Green
Old 06-29-2020, 07:25 AM
