Just looking for clarification Thanks |
1978 911 SC
Mine is now set at 55% with BLACK to green wire on test port & RED to ground. If I reverse this I have a reading of 38% Duty. Can any one confirm what is the proper hook up procedure. Cheers
1978 911 SC Complete rebuild, 83 engine, SSi’s M&K Sports muffler. |
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models: https://nineelevenheaven.wordpress.com/english/ |
With black clip to green wire and red to ground, what duty cycle are we looking for at 1000 rpm idle? Apologies |
1978 911 SC
Took the works out of my mouth..haha thanks Funracer.
This does correspond to approx 0.8 % CO at 50% duty cycle with sensor disconnected, means open loop for doing the test with a CO measuring tool.
![]() So duty cycle 55 for factory idle setting but 40-45 to achieve proper mixture for acceleration and WOT? Sorry Damon88 don’t mean to hijack. Thanks |
55% at idle is for factory standard (max 0.8% CO).
40-45% at idle ends up in a higher AFR at WOT.:-) Sorry I was thinking of my own developed ECU, where you always set idle to 55% duty cycle and you can set the AFR for WOT individually via software.
Got it! Thanks
1978 911 SC
Thanks you Andrew for the clarification. Funracer, I appreciate you starting this thread and helping others from what you learned. This is place is amazing. Thanks again. Cheers Damon
Read here starting at post #15 to see how some hopefully learned about how a Lambda ECU functions and how it's tested;
High dwell on 911 SC ‘81 lambda (US) That was over three years ago, and some still don't fully understand the system and still ask questions!
Dave |
