Driver's License Owner
PMO Plumbing from tunnel
Hoping this is an easy one for someone. Not looking to go to AN fittings yet, so looking for a simple solution. My new fuel lines through the tunnel end at the rear bulkhead with a threaded end that would normally go to the accumulator. Since PMO goes directly to the fuel regulator which has a hose barb fitting, what is the best way to make this transition? Could I just cut off the end that would screw to the accumulator and clamp that to the regulator? What's the common approach?
Thanks -- Chuck 1977 911S Backdate Street/Track, 1970 911T, '70 Triumph GT6+ Vintage Racer Project, '60 MGA Restomod/tribute, Cayman R, 1967 Moto Guzzi V700 |
I just did this and all I can contribute is that going with AN fittings is the simple solution.
-Mark B. Hardware Store Engineer 1988 911 - 3.6 1999 SL500 - Gone 1995 M3 - LS2 - Gone 1993 RS America - Gone |
Senior Advisor
you can also go barbed fittings and use fuel injection hose (or USCG approved fuel line) and fuel injection clamps, easy peasy
08 Cayenne Turbo |
![]() From what I have seen, the original lines continue from the Tunnel and go directly to the original Fuel Filter. This is done either with a short hose extension or if you have an later SC with a Direct Connect fitting like this... ![]() After the filter the feed hose goes to the PMO Fuel Block or the PMO Fuel Rail. Len
![]() I have made up a number of sets of these hoses and would be happy to help anyone with questions. Len.Cummings at verizon.net
![]() Chuck- Have you sorted out your fuel line connection issues yet? Len
