Block hole in Engine Tin for heat delete
What do I use to block off these holes where heat tube went threw tin?http://forums.pelicanparts.com/uploa...1594330198.jpg
there is a piece that the hole does not exist, or I found a long tin piece that forgoes that smaller part all together for my spec car. very rare, but you never know what you might find in the classifieds with a WTB add.
Get a carrera right side, one piece, no hole.
Bruce |
here is an example of each that i used at post #178
http://forums.pelicanparts.com/california-southwest-us-az-nv/443725-plunge-9.html |
Find a tin (or aluminum) can of the right size, cut down, fasten in.
93010686201
https://www.dhresource.com/0x0/f2/al...i44jIb4355.jpg |
did you use both pieces or just the flat cap portion? I used the bottom of beer cans to block off the heater inlet tubes at the body on my racer. i was drinking rolling rocks at the time if i recall..... scroll though my build thread linked above for a number of mcgeiver type things that i thought i was clever with. shopvac attachment cowl to cabin intake, black & decker grinder sides for front rotor venting block off plates and the like. |
I found the 2 short ones with no holes. Factory German from Eimalig
I'm looking for this heat block off plate for left drivers side in metal. Does anyone have one laying around? http://forums.pelicanparts.com/uploa...1594355256.jpg
| All times are GMT -8. The time now is 12:33 PM. |
