Block hole in Engine Tin for heat delete
What do I use to block off these holes where heat tube went threw tin?
Old 07-09-2020, 02:30 PM
disband
juanbenae's Avatar
there is a piece that the hole does not exist, or I found a long tin piece that forgoes that smaller part all together for my spec car. very rare, but you never know what you might find in the classifieds with a WTB add.
Old 07-09-2020, 04:26 PM
Get a carrera right side, one piece, no hole.
Bruce
Old 07-09-2020, 04:30 PM
disband
juanbenae's Avatar
here is an example of each that i used at post #178
the plunge!
Old 07-09-2020, 04:32 PM
Walt Fricke's Avatar
Find a tin (or aluminum) can of the right size, cut down, fasten in.
flyingjay's Avatar
Old 07-09-2020, 04:43 PM
Yes. I used a ball canning jar lid on my heater backdate. I sprayed it with flat black bbq paint and secured it with gasket maker. Less than $1 invested, it works great and doesn’t look too bad, the jar lid is the perfect size and is countersunk a little so it looks like it was meant for it.
_______________________________
1982 911 SC 240,000mi and counting
Old 07-09-2020, 04:51 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Who Will Live... Will See
Old 07-09-2020, 04:58 PM
disband
juanbenae's Avatar
clever, and I love clever!
did you use both pieces or just the flat cap portion? I used the bottom of beer cans to block off the heater inlet tubes at the body on my racer. i was drinking rolling rocks at the time if i recall.....
scroll though my build thread linked above for a number of mcgeiver type things that i thought i was clever with. shopvac attachment cowl to cabin intake, black & decker grinder sides for front rotor venting block off plates and the like.
Old 07-09-2020, 05:24 PM
I found the 2 short ones with no holes. Factory German from Eimalig
Old 07-09-2020, 08:03 PM
I'm looking for this heat block off plate for left drivers side in metal. Does anyone have one laying around?
Old 07-09-2020, 09:27 PM
