under hood clean up?
What can I remove here? I have no AC and backdated heat. I'm starting into a master cylinder replacement and thought I might remove what I can while I'm at it.
Old 06-29-2020, 11:28 AM
Vintage Owner
Jack Stands's Avatar
Most of what you’re seeing is part of the heating/ventilating system - I’d leave it in place unless it’s a race car.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 06-29-2020, 02:12 PM
I believe that elbow coming up from behind the smugglers box is only used with AC. My non-AC car does not have that elbow, but the passenger side, right off the blower, has a Y that feeds air to the central dash vent.
Also, on my non-AC, the elbows above each control box have Y's with smaller hoses to the small left and right dash vents. I thought I had a good picture but can't find one with the cover removed...
1978 SC Targa
Old 06-29-2020, 03:12 PM
Non-of the havoc settings or fans work, heat just oozes from the dash when I lift the center floor levers.
Old 06-29-2020, 05:04 PM
77 Restorer
When I pulled my ventilation system/box to replace the fan motor, much of the control vents inside had deteriorated and needed to be replaced. I probably could've removed most of it since I'm trying to lighten up the car, but these were pretty light and I still get cool air through the old A/C vents. It's easy enough to remove and replace, as needed.
Bert
77 911 Targa (Maize, or Talbot yellow as the case may be)
04 C4S Cabriolet (sold)
Old 07-01-2020, 05:39 PM
Porsche Addict
There is 8 kilos in the smuggler's box.
Lawrence - 1986 911 Carrera Coupe Grand Prix White
1959 Land Rover Series II
1962 Volkswagen Sedan Ragtop
1959 Porsche 356A Coupe
1971 Porsche 911T coupe
Old 07-01-2020, 05:43 PM
If I don't care about the havoc can I just remove all of the blower system behind the master cylinder?
Old 07-13-2020, 08:21 AM
freesaints's Avatar
I removed all the fresh air blower system. Still have AC with an aftermarket system and heat direct to the cabin. I never used the fresh air system. Really cleaned it up.
1987 Porsche 930 - Grand Prix white
1998 Acura NSX - Kaiser silver
1976 Jeep CJ5 - Sunshine yellow
Old 07-13-2020, 08:33 AM
Geronimo -- how do/would you handle a fogged up windshield if you remove everything?
Old 07-13-2020, 08:47 AM
On my ‘82 I ducted the heat directly to defrost vents on either side with SCAT tubing. Works great for defrost and chilly mornings.
Old 07-13-2020, 09:55 AM
I have never touched the in dash controls. The only levers I have ever used are the center floor levers.
The heat has been back dated, so I am not sure what I can get away with. I don't drive the car in the rain, or really the cold much at all.
Old 07-13-2020, 12:15 PM
