the black does not go anywhere ,cut it off.It was for internal regulator and the person before you did not cut it...
Ivan |
Jason |
Most have been upgraded to the external version of the regulator as Porsche recommended in the service bulletin I linked to. I believe that’s what Ivan assumed.
... internal ...
and thanks for the link - will take to shop to day, and if no issue to rebuild will go that route vs. the "upgrade" to internal which would require new air duct etc. Jason |
Yes, I meant internal. I suspect the internal regulator is more "precise" due to being close to the windings... but at a higher temp location for sure than off to the side.
Question - what type of bolts can I use to secure the shroud to the alternator housing, given it is magnesium. Can I use stainless steel?
Jason |
It's 10 x 715 Our host shows 10 x 725 as the appropriate size for my '79, as does other sites. 710 is shown for a turbo. But as in my case if there were 7 shims on the outer side of the "pulley" and none on the inside, wouldn't that suggest that the 715 belt is too long - so how would a 10 x 725 make sense? Or is my thinking flawed? Jason |
Jason, this probably isn't helping... But my '79 has 9.5 x 710.
If you place more shims on the inside you effectively reduce the diameter of the pulley by allowing the belt to sit lower in the "V". In this case you will want a shorter belt. Try the 10 x 710.
Thank you Bill and Walt. Will purchase a 710
Jason |
I fought the fan belt fitment for a while. I finally broke down and bought the Porsche branded belt from Pelican. It simply works right with the normal amounts of shims. I have yet to find a belt that the local FLAPS or any local source that has the precise "correct" size.
You can get a belt to work long enough to get you home, but get the German made proper belt and it is easy, just expensive. |
Always had good luck with Conti, not sure who makes them for Porsche.
goodyear made belts for Porsche...
I lived in Germany for three years up until 2017. I regularly took my 88 3.2 to 6200 RPM in 5th gear and cruised for extended periods above 130 mph. Purred like a kitten. Get that alternator/fan assembly taken care of and push it hard once warmed up!
Since I rarely get to triple digits at all, I will stay with no spoilers. Just a personal preference. |
Alt removal/refitting was a pain but gave me a chance to get some wrenching in and learn more. Looked on line including our host but could not find a sure-fit alt with external VR, and I did not want to go the route of the mod to internal. Brought alt to a local shop and they rebuilt it soup to nuts, but hammered me on the cost ($385). Went to work at the re-installation and kept my fingers crossed that a) I would get alt light with key turned, and b) that when engine fired the light would go out, and the alt would be charging.
Success!: A: http://forums.pelicanparts.com/uploa...1596977263.jpg B: http://forums.pelicanparts.com/uploa...1596977344.jpg Thanks for the suggestions/comments. As a footnote, I replaced the 10 x 725 belt with a 10 x 710 belt; 3 shims inside/3 shims outside and it was good to go. Edit: - I was concerned that the belt might be too tight, so I moved two more shims to the inside; five in, one out Jason |
| All times are GMT -8. The time now is 08:04 AM. |
