CJ CJ is offline
CJ's Avatar
Valve adjustment tip
Just adjusted the valves on my Carrera and it was alot easier than I thought. I think the key was to remove the left and right side engine tin. One troublesome bolt on the tin, and I didn't have to work around the A/C compressor, plus all the intake valves were easily accessible from the bottom side of the car. While the tin is off, it is also really easy to change spark plugs and do a little cleaning.
Chris Johnson
87' 3.4 Carrera
73' 911t restoration project
Old 04-16-2003, 09:06 AM
dickster's Avatar
good tip! since plugs should be changed at about the same interval - thats a great idea.
is it easy to remove the tin?
Rich
'86 coupe
"there you are"
Old 04-16-2003, 09:17 AM
hmmmm.
206 637 4071
Old 04-16-2003, 09:33 AM
dickster's Avatar
hmmmm.
lol, hey, you cant leave it at that!
whats missing?
sounds "sound"!
Rich
'86 coupe
"there you are"
Old 04-16-2003, 09:34 AM
Send a message via ICQ to old_skul
What tin are you talking about removing? The rear part of the car?
Something tells me your engine is out of the car or something.
Mark Szabo
1986 911 Targa 3.2 (I will miss you)
1985 Scirocco 8V (I will not miss you)
1986 Dodge B150 Ram Van (I can't believe I got $200 for you)
1987 Escort 5-speed 1.9 RIP
Old 04-16-2003, 10:38 AM
three bolts and the A/C pump is out of the way. pull it up and lay it on top of the engine with some sort of padding.
206 637 4071
Irrationally exuberant
ChrisBennet's Avatar
I've heard of mechanics removing the engine tin like you say.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 04-16-2003, 10:58 AM
CJ CJ is offline
CJ's Avatar
Mark,
I am talking about the left and right side engine sheet metal, approx. 7 bolts per side, some on the bottom some on the top-all but one are easy to remove. The engine is still in the car. The whole process including valve adjustment took approx. 2 hours and this is the first time I've done a valve adjustment with the motor in the car, and the second one I've ever done.
John,
With the car up on jack stands, and the engine tin removed, It was very easy to adjust the intake valves, no adjusting by "feel" I could see the adjusters on cylinders three and six and get the feeler gauge in there without a problem.
For a beginner, removing the tin made the process less frustrating, more accessible and much more clear.
Chris Johnson
87' 3.4 Carrera
Old 04-16-2003, 12:48 PM
Hmmm, that's a cool idea. The one thing that gets to me, though, is the catalytic converter. Seems like it leaves *so* little room to adjust those 1-2-3 exhaust valves. The 4-5-6 bank is pretty much cake.
Mark Szabo
Old 04-16-2003, 01:14 PM
CJ CJ is offline
CJ's Avatar
Sorry, should have mentioned no cat. SSI's
Chris Johnson
87' 3.4 Carrera
Old 04-16-2003, 01:46 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
wow JW's speachless? I think that deserves a Congrads, you may have just been the first person on this forum to do that.
edit: both render JW speechless and to do the engine tin removal for VA.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 04-16-2003, 01:51 PM
Senior Member
Superman's Avatar
No cat (backdated exhaust). No A/C (useless in PNW). No air ducting on the right side of engine (backdated heat).
The only way to go.
Mocha 1978 911SC. "Coco"
Old 04-16-2003, 01:53 PM
i guess if it made it easier for you, that's what it's all about. it just seems that the two minutes spent moving the A/C pump would make access easy enough. there's quite a bit of room to get at 3 and 6 on a carrera, even though you have to feel the blade go in, as opposed to seeing it.
206 637 4071
Old 04-16-2003, 02:33 PM
See! John wasn't speechless .... He was just mulling!
Howie
79SC
Old 04-17-2003, 12:10 AM
