Limbo
Slider79SC's Avatar
Ground strap
Does the ground strap near the transmission on a 79SC have to be hooked up in order for the car to run right and if so, why was my car running ok without it????
Big ol built Duramax
Durango R/T 19’ Current Custom project
V8 M3 08’ Built and spoiled
Old 04-21-2003, 08:21 AM
addictionMS's Avatar
there are gounds on motor as well, usually, but the more gound you have the better.
Jim
Jim Hamilton
If everything seems under control, your not going fast enough.
Old 04-21-2003, 08:24 AM
Todd Simpson's Avatar
Just put the motor back in my '71 and it wouldn't crank over without it.
Old 04-21-2003, 08:35 AM
Sometimes a ground path will be "found" all by itself, in ways you don't want to do...like the trans linkage and rods becoming a ground path...
Renew OEM ground straps periodically and adding more grounds is a good thing...
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 04-21-2003, 08:50 AM
One of the alternate ground paths for the starter is through the clutch cable. This tends to overheat the steel wires therein, ruining their temper. Then they begin to break and the clutch cable begins to stretch and hangup. Restore your grounds and save yourself a future headache. Jim
Old 04-21-2003, 09:44 AM
Super Moderator
cstreit's Avatar
I'll third these notions. You really don't want your starter current and spark current going back to ground through your clutch and throttle linkages... Even worse were you to have stainless fuel lines... Potential connection there... THat's why I don't use 'em for the last connection point to the motor...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 04-21-2003, 09:50 AM
Limbo
Slider79SC's Avatar
Wow, you guys are scaring me. I just put the motor back in a little while ago so it hasn’t been disconnected for very long. I will not make this mistake again. (yeah right, that’s what we always say)
Old 04-21-2003, 10:11 AM
Being scared is a good thing.....
*IF* it makes you fix a problem that avoids the scare in the first place
Take care..
---Wil Ferch
Wil Ferch
Old 04-21-2003, 01:34 PM
