Front Fender Mounting Bolts - Torque Value?
Can someone please check their 911 service manual to see what the torque values are for the front fender mounting bolts?
Thanks |
Bump
probably no torque value given for those. the idea is to get them tight enough, but not so tight that the two panels distort. it's a feel thing.
Thanks John, I can always count on you. Do you recommended loctite or anything else on the bolt threads?
I just got them tight, and used big washers to distribute the load.
One mistake I made was to straiten out the inner edge of the fender (it had previously been "custom fitted" to follow the hood line, and I also used thick fender putty(body dope?) inbetween which increased the gap even more. |
| All times are GMT -8. The time now is 07:52 AM. |
