Can someone please check their 911 service manual to see what the torque values are for the front fender mounting bolts?
Thanks Last edited by TurboRuf; 04-17-2003 at 03:33 PM.. |
Bump
probably no torque value given for those. the idea is to get them tight enough, but not so tight that the two panels distort. it's a feel thing.
Thanks John, I can always count on you. Do you recommended loctite or anything else on the bolt threads?
85 930 Ruf BTR |
You do not have permissi
I just got them tight, and used big washers to distribute the load.
One mistake I made was to straiten out the inner edge of the fender (it had previously been "custom fitted" to follow the hood line, and I also used thick fender putty(body dope?) inbetween which increased the gap even more. |
