Winter Projects
I remember an interesting thread from last year about everyones winter projects. Sooo.... What was everyone's project and How did they all turn out?
Wow, where to start.
Fixed mixed up headlight wiring, Cleaned and painted jack, New heater box cover, New Targa top covering and headliner, Installed new cigarette lighter, New/Old Radio, New floor mats, Repaired and installed period correct seats, Seats don't have mounting points for seat belts. had to fabricate brackets and install them under the seat rails, Installed period correct mirror, Replaced broken tail light Right now I'm installing new door pockets, old but better condition than I had. Shop work....... Transmission rebuild, New Clutch, Top end Rebuild, Chain tensioner upgrade, Front brake rebuild, The Car is still running rough. lots of popping from the exhaust. I'm thinking maybe the valves need to be readjusted. Still need to replace the cracked dash. (next year) It never ends.
Ken Copeland 70 GT6+ KC78784 70 Spit FDU84919 70 GT6+ KC81551 (Ok so I like 70s) 71 Porsche 911T 00 Chevy Pick UP |
Get ready:
DIY 3.2 engine swap New torsion bars all around Sway Away adjustable spring plates Neatrix bushings Front A-arm bushings That was a lot of fun.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
I would rather be driving
Finished ALL rust repair on the tub. Prepping to paint tub. Not as much as I'd hoped. Definately weather limited.
Jamie
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Almost Done!
Bilstein HD's all around
Elephant Racing A-Arm bearings OEM Front sway bar bushings Rebuild all 4 calipers, sandblast and paint New Rotors & Pads SS Braided Brake lines SandBlast & Paint A-Arms, Front Sway Bar, 2 pans and Bars New ball joints Turbo Tie Rods Repack front wheel bearings and replace one bearing And this was the first time I did ANYTHING on a car other than put in gas and change the oil. It sure was fun.... Dave
Dave Ploss '87 911 Carrera Coupe - Black '90 Mercedes 190E '00 Filippi Lightweight Double |
Rust repair, new left wing and wheel housing (done)
Paint (in the nearest future) Old 2.7 engine out and 3.2 will be installed (after paintwork) Big brakes, torsion bars (under construction) Oil cooler to front and RUF-spoiler will be fitted (just looking for suitable cooler). Any suggestions on pipework, steelbraided all the way or original? KH
KH 964 C2 -90 9-3 1.8t -06 sold 911 3.2 -74 |
Senior Member
Kristian, did you sell that 2.7 liter engine? I might be interested in buying that.
Projects: 911 -72T EFI "964-look" "Smoky" 914 -71 1.7 D-JET "Rusty" |
Full Service
Stainless Steel Brake Lines Some New Hard Brake Lines New Rear Rotors New Rear Pads Rear Caliper Rebuild Bump Steer Kit New Heater Valves New Heater Control Cable Rear Sway Bar Bushings Rear Sway Bar Drop-Links Fan & Surround Clean Up Hopefully be able to go out and drive it now!! Cheers
1984 Carrera - 3.6 Conversion, 326bhp, 1020kg - SOLD 1987 930 - SOLD 1983 911 SC Targa - SOLD http://forums.pelicanparts.com/impactbumpers.com - Classic 911's and nothing else Last edited by AirCooledExcellence; 04-16-2003 at 07:53 AM.. |
Valve adjustment
New belts, plugs, air filter Rebuilt and painted all 4 brake calipers New brake rotors on all 4 corners New pads New SS brake lines New rear wheel bearings New left side rear hub Turbo tie rods Bump steer kit Lowered to 24.25" rear, 24.75" front Calibrated speedometer At that point my wife began asking whether we were finished spending money on the car for awhile so I cut my list short. Now my front wheel bearings are beginning to make noise so they'll probably be replaced soon. And my air conditioner needs some attention. And...
Nate Gone: '86 Carrera coupe Current: a $75 BMW 320i |
Cleaned her up a little made a clock plug and...oh yeah, welded in the complete rear panel!
Keeper of the Titanium Monkey 1975 911S (sold) 1973 911 w/3.2 (sold) 1983 911SC targa (sold) Looking for a 987.2 or 981 Cayman |
Started off as rear brake rebuild progressed to
front S brake rebuild- also stripped flaking black paint off calipers resulting in a nice anodized finish New master cylinder Cleaned surface rust around brake fluid reservoir and painted area with POR15 Rear wheel bearings New trailing arm bushings New Neatrix bushings New Swaybar to trailing arm bushings Used Carrera adjustable spring plates to replace non adjustable ones Rebuilt rear brakes with new pads Used 24.1mm rear torsion bars to replace 23mm One new CV boot New Magnecor wires on the way. Also planning on a tune up and alignment.
Neil '73 911S targa |
just a full cleanup/ inspection.
ohh ya and I ran it a little bit (for the first time in 2 years)
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
Just a few more details. |
Limbo
MT912RS,
Whats up with that rear suspension?????
Big ol built Duramax Durango R/T 19’ Current Custom project V8 M3 08’ Built and spoiled |
That is a big brake/ camber compensator/ roll center idealizer/ toe correction/ coilover kit I am working on. Thanks for asking.
Limbo
So where does that put you within the rules? Do you automatically go up to the GT classes?
It'll be legen-waitforit
Ah yes....the sweepers just finished getting the gravel off (our community), it rained a couple times to get the salt off the roads, and I'm going to fire her up today!!
Projects that are finished are: replace spark wires with magnacore Changed plugs R&R alternator New cap and rotor New hoses - HE, blower Some polish and powdercoat in the engine 100 more right behind them, but gotta drive.
Bob James 06 Cayman S - Money Penny 18 Macan GTS Gone: 79 911SC, 83 944, 05 Cayenne Turbo, 10 Panamera Turbo |
3.8 liters 993RS to freshen my 3.6 liter swap a little ![]()
On a great circle route
Wow, Bill, 3.8 looks great!
Russ |
Here is my list;
- engine/trans drop - replace all gaskets and seals that I could - drilled out broken exhaust studs/install new - installed new heat exchangers/flapper boxes - new engine heat ducting - repaired aux engine fan motor - powder coated engine tin - upgrade chain tensioners/chain ramps - installed pop-off valve - adjusted valves - resurfaced clutch disc - new oil hoses - hot tanked oil tank and por-15'd it - cleaned up engine compartment - installed better wires - Installed new rear shocks - New trunk carpeting - new high-low beam signal light switch and a few more I just can't think of right now Started it up ok and runs good but I have oil leaks and my clutch does not work. aaaarrrrrrggggggg. I'm taking taking a holiday befor I go back to it.
75 targa 2.7 Lean and green |
