Front passenger side is squeaking like an old pickup truck. Suspension is all original except for bilstein inserts/rear shocks 8 years / 8000 miles ago.
I figured it's time to refresh all the 33 year old rubber and make this baby new again. Also planned is it to lower it down just a little bit. Taking it to Warren @ Rennsport in Sealy, TX. Here's what I ordered. Please let me know if I missed anything. From Elephant Racing: Front Sway Bar Bushings Ball Joint Hardware Kits Control Arm Rubber Bushing Kit Steering Rack Spacer Bump Steer Kit Turbo Tie Rods Spring Plate Rubber Bushing Kit Spring Plate Hardware Kit Rear Sway Bar Bushings From Pelican: Ball Joints (Lemforder) Strut Insert - Bilstein B6 Performance Part #: 34-001141-M512 Shock Absorber - Bilstein B6 Performance Part #: 24-001694-M512 OEM Store Strut Mounts Sway Bar Links Steel Cover - 900-040-008-01 Stabilizer Gasket - 901-341-475-00 Trailing arm bushings (had this in hand already) Other items to fix while doing this: Driver door stop Driver side mirror motor HVAC Blower Motor New shift knob & cap Seat Trim Cover 928-521-760-05-01C Indicator Lamp 945-632-212-00 (i am really hope this is the 3 piece one) Appbiz ultimate sound pad Total hit to the wallet: $3150 I didn't order torsion bars. Told Warren to tell me if I need them once he inspects it. Recently completed: New OEM engine mounts New Rennline transmission mounts New Rennline engine bar
1987 Porsche Carrera Coupe |
Vulnerari Praesidio
How many miles on the car?
"Wisdom is knowing what to do next; virtue is doing it." - David Starr Jordan |
Front suspension
Vulnerari Praesidio
Nice. I believe you got it covered.
Other refreshments and repairs since I got the car 2 years ago. I have put 3500 miles on it.
Oil Change Transmission Fluid Change to Mobil 1 Brake/Clutch Fluid Flush Replace air filter Distributor Cap & Rotor - Replace Valve Adjustment, Spark Plugs, Valve Cover Gaskets Axle Seals - Replace Replace fuel filter Adjust idle Replace air flow meter FOCUS 9 TECHNOLOGY SS RELAY Griffiths Reliability Package AC system Replace A/C Compressor Replace Passenger Door Actuator Horn ring on steering wheel & column Adjust parking brake Front Wheel bearings 4 New Tires Window Tint, including windshield Paint Correction Front Paint Protection Film Clean sunroof drains
1987 Porsche Carrera Coupe Last edited by Sajan; 05-22-2020 at 03:38 PM.. |
Just did this myself on an 87. I’d post the pictures but forum doesn’t like iPads
1987 3.2 Carrera Coupe - Venetian Blue Instagram - roblkendrick |
Fb = M/S
I don't see camber plate rubber bushing replacement and bump steer kit on your list. Also, if your car was squeaking, make sure you check your torsion bars. They may be worn and might also need to be replaced.
Good luck.
1981 911SC, Guards Red/Black Leather 2014 Audi A6 Prestige, Phantom Black Pearl/Black Leather, Black Optics 2017 Tesla Model X Gone but not forgotten: 1969 Datsun 2000, 1973 914 1.7, 1976 912E |
Might want to go with some rear sway bar mount reinforcements. I know my '87 needed them when I did my refresh.
Several options out there. I went with the WEVO's. https://www.pelicanparts.com/More_Info/WVORARB.htm?pn=WVO-RARB&utm_source=googleppc&utm_term=WVORARB&utm_campaign=Shopping+Feed&gclid=EAIaIQobChMIvoS7kOrZ6QIVeB-tBh2KJw-1EAQYASABEgIIy_D_BwE |
Location: behind the redwood curtain, (humboldt county) california
Steering rack rebuind
I’d recommend a steering rack overhaul. It has likely never been touched. Parts are cheap, unless you opt for the Quaife “quick” R and P. Also suggest a sealed lower bearing, rather than unsealed. IIRC, Red Dog Motorsports makes a replacement “Puck”.
Tom at Garage Time has a good short tutorial on the process. chris |
Hmmm... My 87 has 259,000 on original bushings and still handles fantastic. Oh yea, it did at one point develop a front end squeak (made me crazy for months) that turned out to be the left swaybar mount that tore off the front pan. Had the muffler shop weld it back on...that's it.
Nothing wrong with going nuclear, at least now you have an excuse, and at the same time, help the economy. Cheers, Joe 87 Carrera on original suspension Last edited by stlrj; 06-01-2020 at 08:11 AM.. |
Dropped off the car today. Excited!
but sometimes you drive it for so long and get used to the way it handles, you forget what a new and refreshed suspension feels like.
Nice..another 87' refresher checking in
what all did you get done? how is it? struts looking pretty
Fb = M/S
https://www.elephantracing.com/porsche/911/bushings-bearings-for-911/rubber-bushings/#camber-plate-rubber-bushing-kit
Yes, the camber plate bushings go on the top of the struts, inside the metal plates.
Quick question. Warren said he might have to drop the engine to get the sound pad in place (which makes replacing rear shocks easier also).
If the engine is dropped, what else should I look at? I searched around and found a few things. I don't want to add a ton of cost to this build so can someone prioritize this for me? For sure I will get ahead of the triangle of death and also replace the fuel lines. What else should I address? Quote:
Porsche Addict
Check oil lines, rear main seal, flywheel, sport clutch?
Lawrence - 1986 911 Carrera Coupe Grand Prix White 1959 Land Rover Series II 1962 Volkswagen Sedan Ragtop 1959 Porsche 356A Coupe 1971 Porsche 911T coupe |
Porsche Addict
I just did this on my car.....
so in a predicted turn of events, engine is out of the car. couldn't loosen trailing arm bolts with engine in place. warren sent over some pics. treat me like an idiot...do things look okay with the engine pic?
the parking brake pad has cracks. looks like the torsion bar has some grooves. ![]() ![]()
