Exhaust system weight data: stock vs M&K
Sharing some basic gravimetric assessments..
Weight of stock system: 65.9lbs/30.0kg Weight of M&K RSR headers and 2:1 exhaust: 29.2lbs/13.3kg Weight removed: 36.7lbs/16.7kg Weekend objective - get it installed.
74 911 3.2 |
cycling has-been
all downhill from here.
getting it separated from the lump was the hard part.
73 911T MFI, 76 912E, 77 Turbo Carrera |
Good info, thanks for posting.
Sent from my Nokia 7.1 using Tapatalk |
I always knew the weight delta was significant, but these hard data are a real eye opener. Another great reason to consider M&K...
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc. '07 Boxter |
Data. Documented. Interesting I checked M&K weight on these components and mine are just a bit under. Confirming why I like buying parts from individual/small suppliers. Like, no robots, man. And we all know the quality/art of Brian’s welding at M&K. I keep track of what comes off and what goes on. Use an old, but calibrated (I have a set of standards from a tag sale find) Hanson scale. It’s not 100% cuz sometimes I skip it and just put the parts on and then think ok I’m not taking that off. At the end - will just weigh the car. Time to install. Debating starting car without the muffler.
74 911 3.2 |
Formerly known as Syzygy
I did that when I changed my muffler. Still had the cat/pre-muffler on, but it was exceedingly loud and sounded like ass. Mighta been different at high RPM under load, but idling, not so great...
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
Here's a vid of first cold startup with a Dansk pre-muffler and the Bisimoto Pulse Chamber muffler (without sound arrestor). On the one hand, a cool lil' piece of kit and on the other hand... a glorified muffler delete. And for grins, here's the unit at shutdwown... It's fun in a super juvenile sorta way and super lightweight, but won't be on for long. I have an M&K Active Exhaust pre-muffler en route. I'll settle on a final muffler choice after I have that installed.
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" Last edited by famoroso; 07-03-2020 at 10:20 AM.. |
Probably a cat, but I'm not sure. Haven't really paid it a lot of attention.
Love to hear it!
Thanks for sharing that weight savings data! M&K are stainless correct?
Yes
Got these installed today. Fitment was exact. Bolted the headers on, set up the straps to attach to engine mount, the headers and 2in/1out all aligned 100%. Was pleasantly surprised when I connected the battery, checked for neutral and in 2 seconds the garage was resonating with flat 6 goodness avec M&K.
74 911 3.2 |
I run the Bisimoto with the sound arrestor. Is it obnoxious...yeah. But It's fun and I have had a crap-ton of compliments on it. Same people that knew me when I owned a GT4 tell me they like the old 911 with the Bisi sound more.
Current: 1984 911 Targa Whale Tail "Gemma" 2014 Boxster S (wife) "Sir Jenson" (She named it...not me) Previous GF's - 986 Boxster S, 987 B Cayman, 981 B Cayman, 981 GT4 |
I just ordered a set of headers for my 2.8 from Brian. They should arrive on Thursday
Can't wait to install. They look great Last edited by 911 SLANT; 07-20-2020 at 07:44 PM.. |
I’ve a set of larger tube With heat headers being built now and a dual in dual s type out being made now by Brian. For my little 2.8 screamer
My headers are also for my 2.8. No heat though. I sold my SSIs. I decided to go with heat deleat. Trying to lighten up my car.
Initial sound clip at idle, car is on jack stands. In my opinion the sound of this M&K system is steely, crisp, tight and toasty with a hint of opulence, and overall intellectually stimulating. I'm excited to wind this engine up to redline.
https://www.youtube.com/watch?v=EMmnjyMdS2k
74 911 3.2 |
I have a 1988 3.2 with a pre muffler and a M&K single in/out. Sounds similar. Wait until you wind it out. It's pretty amazing. Video is at idle, sounds tough.
https://youtu.be/q369ssq3da8
1988 Carrera coupe 1966 250 Ducati 2015 VW Golf TDI gone because Dieselgate! 2021 VW Golf TSI 2014 Ninja 300 |
NEW observation after 150 miles of use - engine runs cooler and steady at 180F. With old "system" temps climbed when stuck in traffic - towards 240F. It's anecodtal - but I think the M&K no heat headers allow more efficient cooling of the engine. Real or? Anyone else observe this?
74 911 3.2 Last edited by shawn908; 08-10-2020 at 03:22 AM.. |
Lovely post
