what is this on my short shift lever?
The previous owner put a short shift kit on my car. I am trying to change the stock shift knob to an aftermarket. All tutorials say to simply knock the old knob off with a 15mm wrench and a hammer. My shift lever has a welded plate under the shift knob. Is this custom or common for the short shift kits?
knob looks stock and moves/twists a little, but has no plans of coming off. ideas? Thanks, Adam |
The picture didn't load
Rescuer of old cars
Factory short shifter has a ring at the base of the knob. Knob still needs to be knocked off in the same manner, but you may need to be creative to find something that will either be bigger and not hit the ring, or get between the ring and the knob. Good luck!
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
undervalued member
i asked my doctor that exact question one time.
you won't like the answer to that if it's the one i got...
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Isn't it just a crush sleeve? grab the knob and twist/pull
72 914-6 GT Conversion 2.7 82 911 SC Coupe 78 SC Targa Hotrod |
and don't hit yourself in the face.
'24 Tesla Model 3, '22 Tesla Model Y '19 Tacoma '06 Carrera, '79 930 '06 S4 Avant |
undervalued member
and there ya go!
OK I'll just keep slamming the knob and hold the shaft.
Thanks |
Wevo and Rennshift screw on
Another option is there may be screw/bolt at the top of the knob (under the cover) holding it to the shaft. If it's not factory, no telling how it attaches.
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires '86 944NA, Sunroof Delete, Track Rat, Full Cage '72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic |
Red Line Service
sozaysven, What year is your 911? 86 and earlier, 915 cars are press on, G50 cars have an allen bolt under the shift pattern cap.
Marc Bixen/Red Line Service West Los Angeles, Ca. www.redlneservice.net / info@redlineservice.net Podcast:"Marc Bixen Live" https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA |
I don't recall the exact size, but you can find an open faced wrench that fits around the shaft and put it under the shift-knob and use a soft/rubber-hammer to tap it off from under the wrench.
That said...I tried that with mine and it was a no-go. I got worried I might screw something up in the tranny with all the hammering, so I just cut the knob off with a dremel.
Current: 1984 911 Targa Whale Tail "Gemma" 2014 Boxster S (wife) "Sir Jenson" (She named it...not me) Previous GF's - 986 Boxster S, 987 B Cayman, 981 B Cayman, 981 GT4 |
I believe that welded collar under the knob is a stop for the factory leather or rubber boot. It can be deleted without any negative issues.
Sherwood |
I use a simple rubber strap wrench and twist the knob off. Much less potential for damaging the knob, and it works quickly every time.
Joe Frantz 73 911 T |
