67 911S Engine temp question
First drive after a 2 year make over. Never driven before.
Runs cold. Maybe 140 if I'm lucky. Its cold here about 15 degrees Celsius.
Normal or ???
Lyndon
Old 08-12-2020, 05:49 AM
140C = 284F
Not cold. Or are you saying 140F?
Sent from my Nokia 7.1 using Tapatalk
Old 08-12-2020, 07:56 AM
On my temp gauge the lowest number is 140. That's where it's running. Seems to cold.
Lyndon
Old 08-12-2020, 08:01 AM
In cool weather my 76 runs at the bottom of the gauge, that's with a 78 motor, SC front oil cooler and no fan. Could be my oil thermostat isn't closing completely and my temp should be higher.
If you don't have a front cooler, bottom of the gauge seems a bit low.
Old 08-12-2020, 08:11 AM
If your thermostat is frozen open it may take long rides to get to temp
At 180 the thermostat, if working correctly, should open to send warm oil to the on board cooler.
Bruce
Old 08-12-2020, 09:09 AM
Must be open then. Serviceable or replace???
Lyndon
Old 08-12-2020, 10:53 AM
Pretty car, by the way
Old 08-12-2020, 10:57 AM
Put it in boiling water and see if reacts to open or close
Bruce
Old 08-12-2020, 11:00 AM
Will do.
Thanks Lyndon
Old 08-12-2020, 11:01 AM
might check for a match between your oil temp sender and gauge. my '76 with a 3.2 swap had the original 3.2 sender with the '76 gauge and acted as you describe. worth a look as it's an easy fix...
1971 914-6 GT 3.6
1974 911
1976 911S leaf green backdate 3.2
Old 08-12-2020, 01:19 PM
