Help needed : fitting a 930 flywheel onto a 3.2
I'm now trying to install a 930 SBH transmission into my 3.2 Carrera engine (part of a turbo project), but I found that the original flywheel has a dowel pin hole to match the one on the crank, but the 930 flywheel don't have that, am I missing something here? .. I tried to browse some 930 images on the web and I see none of them has the dowel pin hole. And if I just pulled the pin on the crank and install the flywheel, will it be balanced anyway I fit it?
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management.
-1987 Carrera Coupe.
-2013 Carrera S PDK Coupe, factory Aero Kit. My DD.
-1987 928S4.
Old 08-16-2020, 11:31 AM
Ok, I just found that the holes will match only one way, but now I can't get that #$#$ pin out of the crankshaft!
-1987 928S4.
Old 08-16-2020, 11:40 AM
Discseven's Avatar
I ran into flywheel fitment problem also for my 930. Turned out they changed flywheels during the year. Forgot if I needed later or earlier.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 08-16-2020, 03:47 PM
The flywheel pin is superfluous
If you’re running moronic you’ll need a TDC marker on the edge of the flywheel, plus cogs
The G50 flywheel can give you the good stack and motioning
The pilot bearing is the big difference between flywheels
Bruce
Old 08-16-2020, 04:21 PM
Thanks guys, I just cut it off and installed the 930 flywheel. things looking good so far.
-1987 928S4.
Old 08-16-2020, 10:06 PM
