-   -   can someone help 81 SC targa under carriage shield (http://forums.pelicanparts.com/porsche-911-technical-forum/1070449-can-someone-help-81-sc-targa-under-carriage-shield.html)
manuyc 08-17-2020 04:26 AM
Is it possible to get an idea where i can find the shield that goes to cover the steering rack and the size of the bolt that hold everything in place. My brother employee by accident threw the parts in the garbage. thanks in advance.
http://forums.pelicanparts.com/uploa...1597663432.jpg
http://forums.pelicanparts.com/uploa...1597663444.jpg
http://forums.pelicanparts.com/uploa...1597663457.jpg
Discseven 08-17-2020 04:41 AM
Manu... LA Dismantler and DC Auto are used Porsche parts resources. They will know what pan and bolts your brother needs to buy for you by the year and make of your car. There are other dismantlers---these are only two of them.
Brian911T 08-17-2020 05:09 AM
Pic from 1978-83 PET
http://forums.pelicanparts.com/uploa...1597665898.gif
#8 N0147212 - Pan-Head Screw M 10 X 25
#7 91134116105 - Protective Plate
Gianni at Pelican Parts 08-17-2020 11:47 AM
The steering rack protective cover is available on our website, click HERE for the replacement piece you're looking for.
sugarwood 08-17-2020 01:23 PM
There are 4 bolts, not just the 2 pan head allen bolts
I think the hex head bolt is M8 x 16.
90007508702
https://i.imgur.com/HMgLnOW.jpg
http://forums.pelicanparts.com/porsche-911-technical-forum/1057339-stupid-belly-pan.html
For installation ease, you need to have weight on the wheels to tighten the belly pan.
Ramps make it easier. Otherwise, Fasten the 2 center bolts, lower car to ground, and then Fasten pan head 2 allen bolts.
Make sure you fully tighten the pan head bolts or else you will get clunking
https://i.imgur.com/242WkYG.jpg
john walker's workshop 08-17-2020 01:56 PM
The circle is a 10mm nut. I install the pan with the car on the hoist, no problem.
manuyc 08-17-2020 06:11 PM
thank you so much for the quick feedback!
manuyc 08-17-2020 06:14 PM
thanks for the tip.
90007508702
thank you for detailed pic.
