can someone help 81 SC targa under carriage shield
Is it possible to get an idea where i can find the shield that goes to cover the steering rack and the size of the bolt that hold everything in place. My brother employee by accident threw the parts in the garbage. thanks in advance.
06 E55 600HP 08 Clk63 black series 590HP 81 SC targa 3.0 91 E34 M5 |
Manu... LA Dismantler and DC Auto are used Porsche parts resources. They will know what pan and bolts your brother needs to buy for you by the year and make of your car. There are other dismantlers---these are only two of them.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Pic from 1978-83 PET
![]() #8 N0147212 - Pan-Head Screw M 10 X 25 #7 91134116105 - Protective Plate |
The steering rack protective cover is available on our website, click HERE for the replacement piece you're looking for.
There are 4 bolts, not just the 2 pan head allen bolts
I think the hex head bolt is M8 x 16. 90007508702 ![]() Stupid @$*%# belly pan For installation ease, you need to have weight on the wheels to tighten the belly pan. Ramps make it easier. Otherwise, Fasten the 2 center bolts, lower car to ground, and then Fasten pan head 2 allen bolts. Make sure you fully tighten the pan head bolts or else you will get clunking
1986 Bosch Icon Wipers coupe. Last edited by sugarwood; 08-17-2020 at 01:31 PM.. |
The circle is a 10mm nut. I install the pan with the car on the hoist, no problem.
thank you so much for the quick feedback!
thanks for the tip.
thank you for detailed pic.
