-   -   Side pop out window sealing strip (http://forums.pelicanparts.com/porsche-911-technical-forum/1071036-side-pop-out-window-sealing-strip.html)
Forssling 08-23-2020 03:57 AM
Hi All,
I'm putting a -71T back together which I bought in boxes.
Where does part 90154349320 go, nr 26 in the PET?
Or is it not necessary when the outer seal on the window frame has got a rubber lip that goes between door seal and B-pillar.
Thanks for any input!
Jörgen Forssling
Gothenburg
SWEDEN
http://forums.pelicanparts.com/uploa...1598180158.jpg
http://forums.pelicanparts.com/uploa...1598180158.JPG
Dpmulvan 08-23-2020 08:10 AM
I think you cut slits in it for the b pillar mounts and it goes between outer b pillar and window frame.
Just guessing.
Forssling 08-23-2020 09:06 AM
Just guessing.
Appreciate your input. From the video link below, I could not see that it went that way. Anyone that can have a look at a similar car?
https://www.youtube.com/watch?v=kiMAzfqS3GY
//Jörgen
Arne2 08-23-2020 10:00 AM
It is glued to the forward side of the B pillar. See here and the other thread linked there.
Forssling 08-23-2020 10:06 AM
Thanks a lot! Is this still needed even though I have the lip on the outer seal, seen in third photo in my first post? It seems to have been a design change in the weatherstripping.
//Jörgen
Arne2 08-24-2020 04:54 PM
The two flaps over lap. The glued one goes from the inside out, the one on the window seal goes from the outside in. If you leave out the glued one, you can see the untrimmed side of the B pillar from the outside of the car.
