Side pop out window sealing strip
Hi All,
I'm putting a -71T back together which I bought in boxes. Where does part 90154349320 go, nr 26 in the PET? Or is it not necessary when the outer seal on the window frame has got a rubber lip that goes between door seal and B-pillar. Thanks for any input! Jörgen Forssling Gothenburg SWEDEN ![]() ![]() |
I think you cut slits in it for the b pillar mounts and it goes between outer b pillar and window frame.
Just guessing. |
https://www.youtube.com/watch?v=kiMAzfqS3GY //Jörgen |
Rescuer of old cars
It is glued to the forward side of the B pillar. See here and the other thread linked there.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 Last edited by Arne2; 08-23-2020 at 10:02 AM.. |
//Jörgen Last edited by Forssling; 08-23-2020 at 10:15 AM.. |
Rescuer of old cars
The two flaps over lap. The glued one goes from the inside out, the one on the window seal goes from the outside in. If you leave out the glued one, you can see the untrimmed side of the B pillar from the outside of the car.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
