MS2 missing tooth alignment
So I want to make sure I have this correct before I thread lock and install. Does the missing tooth go before or after TDC. Searching this forum I have seen both applications. Originally I thought it didn't matter and you set it in the program, but then I saw someone needed to redrill their 36-1 wheel to properly align the Clewett pulley. Thanks!
Before TDC ![]() After TDC
83' Coupe - Ex-RaceCar 77' Targa Narrow Body - SC powered Copper Brown Metallic |
Spoke with Clewett. The missing teeth go after Z1. In between Z1 and the 30 degree mark.
