fuel pump adapt
Good morning. we are installing a 3.2 Motronic engine into a 3.0 CIS car. I haven't bothered to look up the different specs on fuel pressure and delivery for the specific pumps, and will do that at some time today, but will a Motronic engine run correctly off of a CIS pump. Thanks, Bob
R... here's CIS and Mo links I recently looked at. Not saying they're right. Is cross ref to whatever you find.
CIS - 911 CIS Primer - Fuel Pressures Mo - https://www.porscherepair.us/porsche-911-1984-1989/fuel-supply.html (Fuel pressures are noted about half way down document.)
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
The volume is approximatley the same, but 5.2 bar for CIS and 2.5 bar for Motronic. Concerns that the additional pressure from the CIS pump will present a problem for the fuel regulator/damper on the Motronic, but with the return, maybe not. Any one with having tried this? Bob
After I converted my 930 to Motec, I continued to use the same 044 pump as I ran with CIS. Any pump that can achieve satisfactory flow at CIS pressures will be yawning and loafing with EFI - and will achieve at least the same flow (if not considerably better) with EFI, for lower current draw. It's not an issue.
'77 S with '78 930 power and a few other things. |
I’ve done conversions 3.0 to 3.2 since the late 80s Many times and never had a problem or concern of using the SC pump. I recall questioning the install in the 80s an out the pressures and told the regulators on the rails controlled the pressures for motronic.
Bruce |
