spring plate bushing replacement?
On my 86, the spring plate center is closer to the top than to the bottom of the bushing housing (car is off wheels) . The rubber still looks fine as far as I can see without disassembly. When is it appropriate to replace the bushings? I am not going the polyurethane way, I hate the noise. Are rubbers available?
Alexander
Old 08-20-2020, 04:46 AM
BER BER is offline
BER's Avatar
Porsche Crest
It would be helpful to know the mileage on your 911 and remember, your bushings are 24 years old.
I replaced my bushings (front and rear) about 10 years ago. I put poly-bronze bushings on the front (no noise) and Neatrix on the rear. I am seriously considering putting poly bronze on the rear this winter.
Elephant Racing sells the rubber bushings for your car.
https://www.elephantracing.com/porsche/911/bushings-bearings-for-911/rubber-bushings/
Bruce
'12 Carrera S DFI
'84 911 Carrera
Old 08-20-2020, 05:03 AM
That's about what mine looked like when I replaced them. Our host carries several options of aftermarket rubber replacements, plus a poly / bronze hybrid bushing kit.
I went delrin for a while then switched back to rubber myself. The product I have apparently no longer exists, but it's a firmer-than-stock replacement similar to what our host carries, it's fine.
Matt - 84 Carrera
Old 08-20-2020, 05:05 AM
MBAtarga's Avatar
'86 - makes them 34 years old!
Mark
'83 SC Targa - since 5/5/2001
Old 08-20-2020, 06:04 AM
911tracker85's Avatar
those rubber bushings were deformed like that on my 78 911 project. that makes my car 42 yrs old?
got the stock rubber bushings from ER.
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 08-20-2020, 06:55 AM
There are a lot of threads on this. I got the wrong bushings sent from Pelican which were hard, almost plastic material. The squeaking was horrible. Pelican was happy to send the correct, more "rubber like" ones and they are much better, however they STILL squeak when driven in cold weather. This is b/c the replacement rubber never really adheres to the tube like it did from the factory. I found a really good 3M epoxy that was designed for rubber and steel and was totally useless. Removing the old rubber is a major PITA. After it was all said and done someone, can't recall who, mentioned that you can just flip them to the other side! I wish I'd known that!
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 08-20-2020, 09:17 AM
It's a 105.000 miles car. Thanks all for your replies.
Old 08-20-2020, 12:36 PM
Location: behind the redwood curtain, (humboldt county) california
it depends....
Hi Alex,
It depends a lot on how you want your car to perform. Porsche designed the car to perform well for a broad market, that is guys going towork, week end autoXers, but generally a more performance oriented market.
Your maintenance of the car can be anything from totally stock, to bumping each item up a bit for more performance/ or allthe way to track prep.
front or rear torsion bar and or bushing replacement willrequire a corner balance and re-alignment. this is not a small expense, so, it is "wise" to plan ahead, get some professional advice, (like Chuck at Elephant) to help you go through your suspensionm in a practical/economical manner.
There are many threads, here to help you do the work, or choose your parts..
Everyone has their own desired levle of performance, comfort, money, so talk it up a bit with your buds.
I really want to sharpen up my dads porsches perfformance and im willing to suffer considerable NVH and cost to make it what i want.
I like Chuck, at Elephant. I talked to him at length about what i have and what i want. I feel confident with his advice, so i have stayed with rubber bushings, slightly stiffer T bars, Carrera sways and bilsteins. It is easy to succumb to the allure of racing hardware, but an honest supplier will give you good advice, appropriat for your needs.
Given the cost of the work, cornerweighting and alignment, this is money well spent.
chris
Old 08-20-2020, 04:58 PM
rokemester's Avatar
105K, barely broken in!
Northeast Ohio
1987 Porsche 911 Targa
1966 VW Beetle, 6V
Old 08-20-2020, 05:41 PM
rokemester's Avatar
Suspension is the slipperiest of the slippery slopes.
Northeast Ohio
1966 VW Beetle, 6V
Old 08-20-2020, 05:45 PM
Yeah, those are shot. Elephant rubber front / rear torsion bar and sway bar bushings, shocks (Bilstein greens) and a good alignment. Maybe add some turbo tie rods.
You can certainly do more, fancier stuff, but the above will transform how the car rides and handles without the compromises or cost that comes with performance parts.
1989 Carrera
Former flings...
2009 Carrera S (x2), 1986 Carrera, 1997 993, 1983 911SC, 1995 993, 1987 Carrera, 1985 Carrera
Old 08-20-2020, 09:05 PM
thanks all, I'll stick to the rubbers bushings already bought them. Will be a winter project.
Old 09-03-2020, 04:32 AM
The slope
Be prepared, ($$$, time), for fixing problems or maintenance items you uncover, "While in there": CV boots, torn rear bar mounts, cracked brake hoses, brake pads, discs, wheel bearings.
Then there are the, "well heck, as long as i'm in there" stuff, might as well do this or that since all the stuff is out of the way, powder coating parts, brake cooling kit, steering rack overhaul, pedal cluster rebush, master cylinder, strut top bushings.
One helpfull decision point - do work that would normally require an alignment and or corner weighting and leave the other stuff for a later adventure. You do not want to pay for several corner weightings/alignments.
Looking back, i'm a bit amazed at the depth and width of my slide.
good luck,
chris
Old 09-03-2020, 08:01 AM
good luck,
chris
I know what you mean. I restored (actually a full body off rebuild) a Corvette C2 and as the saying goes: you start with wanting to replace a light bulb in the glove box, and all at once you find yourself with a bare chassis surrounded by zillion parts. Been there, done that
Old 09-04-2020, 02:28 PM
