Porsche 3.2 injectors
Has anyone tried these???
This is from the thread from Sal Carsellar and i am reviving it under new post:: Quote by Wayne 962 So, I've been doing a search for alternative part numbers for injectors, and this page came up: https://www.********.com/en/moreinfo.php?pk=533438&jsn=262 This would seem to imply that this AC DELCO injector (probably made by BOSCH for them) is similar / interchangeable with the following? ACDELCO 2172269 Alternate/OEM Part Number(s): 0280150201, 0280150352, 0280150360, 0280150364, 0280150634, 13641273272, 19110469 The 360 and 364 numbers lend credence to the theory? Here's another discussion where someone points out the same thing: https://www.impactbumpers.com/forum/index.php?/topic/30960-32-carrera-fuel-injector-alternative/ I wonder if anyone has done any further research on this? Injectors are available from Porsche for about $350 each (and I'm not sure if they are rebuilt or new!), and these are $40 each it would seem and still available? -Wayne |
Any updates? The buick and bmw inj are long gone. There has to be a new cheaper alternative than porsche brand which at a discount are $300 each
I have misplaced my stock 3.2 injectors. My rngine builder needs injectors to finally get my engine done, installed with tebuilt trans and get my 86 carerra running after 4 years!!!
Help me please! |
I replaced mine with a Bosch set from a 4.0 Jeep #0280155784. It seems to run much better than my old stock set, though the farthest it’s been was up and down my street.
I installed a set of Lucas D1540BA injectors this spring. I purchased them from FiveOMotorsport. They are a drop in low impedance replacement with specs matching the stock Bosch injectors. My car is running great with these injectors.
Forum member Peter M found a set of affordable, modern Bosch injectors that he switched to with good results. I'm considering trying these myself.
https://porscheforum.com.au/topic/11530-replacement-fuel-injectors-for-32s-whys-it-so-hard/ |
The 9 Store
I have a set that came from a running engine. $150 + 8 priority ship. If you like, I can send them directly to mr injector for cleaning and new seals. The cleaning is optional and payment would be on you but he flow tests before and after so you know what you have. I’m at Mark@MarkEpstein.net or PM me. Pics if you want.
All used parts sold as is. |
Irrationally exuberant
I may have some in my stash I can send you.
I’ll check tomorrow. OK, I checked just now. I gave them to someone. I’ll point him to this thread.
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ Last edited by ChrisBennet; 09-05-2020 at 07:47 PM.. |
Wow thank you everybody for the advice and offers. This is a great forum. Sal Carseller is sending me his loaner aet as i am going to get his MAF i j and DME setup. PP forum rescued my project! Woody
