Patporscheguy's Avatar
Uhh help...
I am doing a clutch job and I made a classic rookie mistake when reinstalling the flywheel, I left the small spacer plate out. This piece goes between the flywheel and the bolts. I was wondering if I need it because I have already tightened the bolts to about 60ft-lbs. Also, could I just take the bolts out and then re-use them because I didn't tighten them all the way?
Thanks,
Pat
74 911 - First Car
Currently Restoring
Old 04-20-2003, 11:21 AM
Navin Johnson
TimT's Avatar
If you havent tensioned the bolts all the way, they can be removed and reused. Install the plate and install and tension the flywheel bolts
'69 911 GT-5
'75 914 GT-3
and others
Old 04-20-2003, 11:41 AM
PRO Motorsports
Tyson Schmidt's Avatar
My Boss recently informed me that Porsche is now saying that flywheel bolts are reusable. Hmmm.... wonder what changed. ???
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 04-20-2003, 04:01 PM
addictionMS's Avatar
I have reused them on many occasions, but I use red loctite on them to be sure all is OK.
Jim
Jim Hamilton
If everything seems under control, your not going fast enough.
Old 04-20-2003, 07:14 PM
I have never replaced my flywheel bolts, a bit or blue loctite is used though.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 04-20-2003, 08:36 PM
