MFI belt cam seal leaks
This is a new seal at the MFP sprocket side of the 1-4 cam shaft. Less than 200 miles new and it is still leaking.
What is the secret to make this leak go away?
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
A thought. I once had a 72 T with MFI. First the rear crankshaft seal leaked then left camshaft seal then forward crankshaft seal. Found oil dilution with fuel caused by the MFI running too rich. Fixed the MFI issues and the leaks stopped. Rob
(man/dude)
That's a funky looking seal. Almost looks like the ID doesnt match the cam. Mind you it would be leaking quite a bit if that was the case.
I would try a new seal.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
yelcab..what we used to do .Remove the spring from the seal unhook-by twisting counter clockwise ,where it is married together.Then cut off about 3mm and put it back together..by twisting ..that will do the trick
unless you have the wrong seal for 930 pump in it? Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 09-05-2020 at 09:12 AM.. |
also look at the end of the cam for some scratch ..install it a little deeper
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
A lot of times the cam has a terrible Grove in it and the seal will not contact correctly. I have used speedi sleeves to fix this. They have many sizes available and you can get them at Napa.
